996 Turbo Forum 1999-2005
What did you do to your 996TT today?
Old 03-17-2017, 12:39 PM
  #3136
405
405's Avatar
Thanks!
I actually pieced the kit together myself from eBay and pelicanparts. The front calipers are new OE 996 GT3 PCCB yellow, w/ TRW pads (Iirc the producer of the OE Porsche pads). Sourced from eBay
New 997TT steel rotors at all 4 corners from Sebro Germany, which are 350mm vs the standard 996 turbo 330mm. Also sourced from eBay. The front 6 pot GT3 brakes bolt up to the 350mm rotors.
The rear calipers are stock 996 turbo refinished to Speed Yellow to match the front, with the AP rear caliper spacers and 997TT extended bolts to space the caliper out for the larger 997TT rotor. TRW pads in the rear as well. Pads came from pelicanparts.
I was able to piece together this kit for surprisingly cheaper than I was expecting. eBay turned out to be a great source for the calipers and rotors.
Old 03-17-2017, 02:43 PM
  #3137
"02996ttx50
"02996ttx50's Avatar
drove another 100 or so miles trying to unsuccessfully ( once again ) set a readiness monitor. so, basically did "nothing" hah.
Old 03-17-2017, 03:36 PM
  #3138
brooksp85
brooksp85's Avatar
Nothing
Old 03-17-2017, 06:17 PM
  #3139
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,236 Likes on 1,442 Posts
Originally Posted by brooksp85
Nothing
+1
Old 03-18-2017, 01:37 PM
  #3140
napoleon1981
napoleon1981's Avatar
Took the car for a drive this morning to bed in the brakes. The car drives like a new car again after the complete front end rebuild. Very happy. Not even the slightest vibration in the steering wheel.
Old 03-19-2017, 12:19 AM
  #3141
mark_schnell
mark_schnell's Avatar
Added 300 miles on the odometer driving with the PCA-SB folks up to Lake Hughes via back-country roads.
Then took it to the car wash to remove the insect carcasses.
Old 03-19-2017, 12:35 PM
  #3142
kmagnuss
kmagnuss's Avatar
Front and rear gear oil change. I was half tempted to pull out the front driveshaft while I was in there but got lazy.
Old 03-19-2017, 08:27 PM
  #3143
bugeyemilo
bugeyemilo's Avatar
Porsche Euro Recaro GT3 seats. Damn these are good
Old 03-19-2017, 09:52 PM
  #3144
911-AL
911-AL's Avatar
Originally Posted by 405
Thanks!
That came out great Chase! Glad to see you're taking her to the next level.
Old 03-20-2017, 09:14 AM
  #3145
405
405's Avatar
Thanks Al!
Old 03-20-2017, 02:54 PM
  #3146
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Lol...NEIGHBOR rebuilt his calipers...again
Old 03-23-2017, 06:35 PM
  #3147
KC-CarGuy
KC-CarGuy's Avatar
Nothing. Stuck traveling over the last few weekends.
Old 03-24-2017, 01:50 PM
  #3148
T10Chris
T10Chris's Avatar
Wasn't today, but I installed a 997.2 GT3 shifter earlier this week. Brilliant, love it.
Old 03-24-2017, 02:06 PM
  #3149
Berra
Berra's Avatar
I see that some use that instead of the 997 SSK. What's the difference?
Old 03-24-2017, 02:19 PM
  #3150
powdrhound
powdrhound's Avatar
Received 1,723 Likes on 1,003 Posts
997SSK is all plastic. The 997.2GT3 shifter has more metal bushings in it. It has longer throws than the 997SSK because it is designed to be used with the shorter shift lever that is mounted on the GT3 gearbox. The now discontinued 996Cup shifter had even more metal in it and even a slightly longer throw. All the GT and Cup gearboxes used the short selector lever essentially creating a short shifter at the gearbox. It's a $90 part that can be retrofitted to the TT Gbox..
Quick Reply: What did you do to your 996TT today?
