996 Turbo Forum 1999-2005
* 996TT REPLACEMENT discs - GiroDiscs. Comprehensive information & pictures*
Old 04-19-2009, 05:19 PM
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Lightbulb * 996TT REPLACEMENT discs - GiroDiscs. Comprehensive information & pictures*
Company verbage & information:
GiroDisc is a brake technology company that is dedicated to the development and manufacturing of high quality brake components and brake systems. GiroDisc products are designed and engineered for both street and track applications with a comprehensive product line of two-piece
floating rotors that are designed to be a direct replacement for the factory rotors.
The two-piece floating rotor will improve braking performance, reduce unsprung weight and utilizes the factory calipers and e-brake.
Unlike many “big brake” packages on the market, GiroDisc rotors also retain the factory brake bias and outstanding pedal feel. High quality construction and premium grade materials provide improved wear, increased rotor life, minimized coning and greater cooling efficiency.
Note how the slotting is *properly* done with tapered ends and plenty of edge margin.
These represent good value, readily available replacement parts, and amongst the highest quality in the industry.
PORSCHE 997 TURBO ROTOR PACKAGES TO REPLACE THE OEM STEEL ROTORS:
SIZE: Front: Factory 330 mm/GiroDisc 350 mm | Rear: Factory 330 mm/GiroDisc 350 mm
WEIGHT:
Front: Factory 24 lbs./GiroDisc 22.4 lbs. - slotted
Rear: Factory 20.5 lbs./GiroDisc 18.2 lbs. - slotted
ALL hardware as weel as the disc is FULLY PLATED to resist corrosion.
100% Made in the USA.
Rotor replacement cost approx $300/ring for cost effiecent replacements -
** ANY questions, please call me at 425-765-1090 or email at rennstore@comcast.net for special Rennlist pricing. **
Old 04-19-2009, 05:32 PM
Oak
Oak's Avatar
do you offer these for direct replacements for GT2/3 front?
also do you have a kit for upgrading 330 rears to 350 utiliazing the stock 330 rear calipers?
since you are a pagid distributor, pagid pads will fit with no modifications?
Old 04-19-2009, 05:43 PM
TrackDays247.com
Former Vendor
I do indeed. Go over to the GT2/GT3 Rennlist section -
The rears are also 350mm and utilize both F&R stock calipers - all parts included.
Extraordinarily easy installation.
*Pagid pads fit w/o any modifications, and BTW do not require ANY manufacturer-specific pad*
I have them right here, any additional pictures just e-mail me. Several sets going out Monday, these are the best of the best and are reasonably priced - UNDER $600 per corner.
Old 04-19-2009, 09:35 PM
Land Jet
Land Jet's Avatar
Craig, how do these compare to the Brembo and AP discs?
Old 04-19-2009, 10:40 PM
TrackDays247.com
Former Vendor
Extremely well - and I sell both the others.
If it were my money, I'd have absolutely NO hesitation purchasing the GiroDiscs -
Once you have both in-hand, I cannot see why one would pay over 1k more for the others.
Old 04-20-2009, 04:13 PM
Oak
Oak's Avatar
craig, sent you an email.
Old 04-20-2009, 05:12 PM
TrackDays247.com
Former Vendor
Rotors are Zinc plated -
Old 04-21-2009, 07:56 PM
manny_g
manny_g's Avatar
can you get drilled/perforated rotors as well?
Old 04-21-2009, 08:36 PM
TrackDays247.com
Former Vendor
They do have an option of drilled & slotted together -
Old 04-30-2009, 12:08 AM
TrackDays247.com
Former Vendor
Just for fun - Walter Rohrl playing with a TT in Germany - with GiroDiscs:
http://www.youtube.com/watch?v=0iK4d...e=channel_page
http://www.youtube.com/watch?v=xMnPz...e=channel_page
GiroDiscs are HUGE in Germany, very common / popular.
Cargraphic uses them almost exclusively.
Old 04-30-2009, 11:20 AM
Joe Weinstein
Joe Weinstein's Avatar
100% made in the U.S.A. but also very big in Germany?
Old 04-30-2009, 11:34 AM
TrackDays247.com
Former Vendor
Yes. A bit of irony, perhaps?
Old 04-30-2009, 12:49 PM
Joe Weinstein
The disk itself should be very irony, but the center part is aluminumy. (i crack myself up!)
Old 05-02-2009, 12:50 AM
TrackDays247.com
Former Vendor
https://rennlist.com/forums/996-turb...-4-wheels.html
Old 10-24-2009, 12:33 AM
TrackDays247.com
Former Vendor
Give me a shout. Rotors now ship anywhere AT NO CHAREGE within the US via UPS - with mention of this post!
Craig - rennstore@comcast.net
Quick Reply: * 996TT REPLACEMENT discs - GiroDiscs. Comprehensive information & pictures*
