996 Turbo Forum 1999-2005
Antifreeze concerns ... is G12 safe long-term?
Old 01-26-2008, 08:45 PM
FixedWing
FixedWing's Avatar
Default Antifreeze concerns ... is G12 safe long-term?
As I understand it, our Porsches came with pink G12 antifreeze:
G12 is on OAT type antifreeze and in fact, DEX-COOL is very similar. It is specified as a replacement for it (by the industry, not by Porsche which still calls for G12) and is mixable:
http://www.valvoline.com/zerex/pdf/Z...d=1B5D1AEA1AFC
According to Porsche, G12 in our cars is a lifetime antifreeze. But DEX-COOL is not a lifetime antifreeze and is meant to be changed every 5 years / 150,000 miles:
http://www.valvoline.com/pages/produ...asp?product=11
Our cars are now at the five year point.
What's more, Audi also called for G12 in their cars. But there have been problems and issues with DEX-COOL related to damage to aluminium and plastics which also implicated G12. For that reason, Audi has quietly upgraded to G12 Plus:
It is purple instead of pink. G12 Plus is a HOAT antifreeze rather than OAT. They no longer put pink G12 in their cars though I believe Porsche still does.
Audi engines tend to need to have their timing belts changed periodically. When they do, it is normal practice to also replace the water pump and thermostat. Of course, you replace the fluid at the same time. So the Audi fleet is slowly upgrading as the maintenace is done. This is not true with our cars.
Has anyone else considered this issue? I found nothing posted.
Stephen
Old 01-26-2008, 09:49 PM
Kevin
Kevin's Avatar
The '01's and '02 came with green antifreeze, it has now been updated to the pink. I haven't seen any info on the Purple HOAT fluid.
Old 01-26-2008, 09:50 PM
Kevin
Kevin's Avatar
I forgot to mention that recently I undid a genuine Porsche antifreeze bottle and under the cap the safety seal said Zerex!!
Old 01-27-2008, 10:28 AM
FixedWing
FixedWing's Avatar
I'm not at all surprised by this. Zerex is manufacturing a lot of these specialised fluids. Original G12 is, if I remember correctly, actually Zerex's original G30 formula.
Not sure my 2001 came with green in Europe. I seem to remember it being pink. But I'm not in Europe now so I cannot check and see. It is quite possible that there was a difference between Europe and North America because at least some of these changes have been due to environmental laws.
Stephen
Old 10-31-2008, 10:58 AM
joyride5
joyride5's Avatar
Can we use the G12+ purple coolant to fill? Is it compatible w/ the 01/02 green coolant?
Old 10-31-2008, 11:20 AM
Land Jet
Land Jet's Avatar
My 2002 has green antifreeze in it. The fluid is now 6 years old. Should I change it and if yes, do I tell the dealer green or pink?
Old 10-31-2008, 12:37 PM
joyride5
joyride5's Avatar
I would change out 6 yr old coolant.. I don't believe in "lifetime" fluids.
Porsche doesn't sell the green stuff anymore. You can mix green with the new pink coolant. However, you will be doing a full flush so mixing is not a concern anyways.
Instead of buying the VW/AUDI stuff, I just ordered 4 gallons of Porsche coolant.
Old 10-31-2008, 02:44 PM
Kevin
Kevin's Avatar
I recommend joyrides suggestions and statement. Zerex manufactures the latest coolant for Porsche. However, it is blended specific for Porsche. Don't mess around with coolant issues. If your car has 4 year old coolant>dump it and purchase the Original Porsche fluid. Buy a new "blue" coolant cap.
Old 01-28-2013, 11:47 PM
RogueM3
RogueM3's Avatar
Another old thread bump (hopefully last one tonight).
Any definitive data that the G12+ as currently sold by Audi works in the 996TT?
ECS Tuning sells Porsche coolant for $31/gallon. My Audi dealer has coolant for about $6 less/gallon. Worth it to save the $12+ shipping ($25 total) on 2 gallons of coolant....Or pony up the extra $$ for Porsche coolant?
Thanks!
Old 01-29-2013, 01:10 AM
TabulaRasa
3rd Gear
TabulaRasa's Avatar
Purple G12+ is mixable with red G12 as far as I know.
Quick Reply: Antifreeze concerns ... is G12 safe long-term?
