996 GT2/GT3 Forum 1999-2005
So you want a bit more camber...
Old 01-27-2017, 12:33 AM
rbahr
rbahr's Avatar
Default So you want a bit more camber...
For various (probably dumb) reasons, I picked up a pair
of these:
As you can see, the 997 parts (97.341.541.0R) are a bit longer. What you use if you exceed 20mm of spacers.
The Hirshmann # is 01.7255.199 and the OTHER number is 997.341.441.9B AS01
Ray
Old 01-27-2017, 12:54 PM
powdrhound
powdrhound's Avatar
Received 1,723 Likes on 1,003 Posts
I'm running the short bearing flanges (997.331.441.9B) and I have 3.5º camber with only a single 1mm shim and tops flipped. With standard tops I had to run 12mm shims to get same camber. The longer bearing flanges you bought should be part number 997.331.441.9C. They will give you another 1-1.5º camber.
Old 01-28-2017, 07:20 PM
jimk04
jimk04's Avatar
I have a pair of the long inners but with street rubber bushings....FYI!
Old 01-28-2017, 11:20 PM
rbahr
rbahr's Avatar
Are you referring to rubber, or monoballs with rubber sleeves?
Old 01-30-2017, 03:16 AM
jimk04
jimk04's Avatar
Rubber Street type bearing in the 997 long inner casting. Looking for pics...
Old 01-30-2017, 03:21 AM
jimk04
jimk04's Avatar
Here on the left....long casting....Street bushing.....don't know what they were off.
Old 01-30-2017, 08:14 AM
rbahr
rbahr's Avatar
Interesting, same part as I have, except mine came from a RSR.
Ray
Old 01-30-2017, 07:40 PM
lordpantsington
lordpantsington's Avatar
Wouldn't be the first time I've seen different parts (machining/bearing differences) with the same casting number.
Old 01-30-2017, 09:25 PM
powdrhound
powdrhound's Avatar
The casting number is not the part number. Porsche uses the same castings for may different applications using rubber or monoball bushings, some street, some Cup/RSR.
Old 01-30-2017, 09:40 PM
rbahr
rbahr's Avatar
Yep,
Agree on both counts - although sometimes the PN & casting # are the same...
I have seen that with some of the RSR stuff...
Ray
Old 01-31-2017, 03:41 PM
jimk04
jimk04's Avatar
Also agree, but I could never fathom what Porsche would offer with long inners but Street rubber bush?!
Old 02-01-2017, 12:56 AM
pete95zhn
Basic Site Sponsor
pete95zhn's Avatar
GT2/3 RS (?)
Quick Reply: So you want a bit more camber...
