996 GT2/GT3 Forum 1999-2005
997 GT3 Rear Toe Link to Replace 996 GT3 Rear Toe Link - Experience Anyone?
Old 05-29-2015, 01:32 PM
AP328
AP328's Avatar
Default 997 GT3 Rear Toe Link to Replace 996 GT3 Rear Toe Link - Experience Anyone?
Porsche has superseded the 996 Rear Toe Link which is known to introduce rear end "wiggle" with a 997 part. I know there are aftermarket replacements available from a number of sources, but has anyone replaced their 996 Rear Toe Link with the 997 part? I haven't heard concerns about 997 GT3 Rear Toe Link, but others may have.
Old 05-29-2015, 05:14 PM
Gadsby
Gadsby's Avatar
They are interchangeable, should not be an issue.
Old 05-30-2015, 03:15 PM
AP328
AP328's Avatar
I don't think I was clear. I am not worried whether the part in interchangeable, but whether the 997 GT3 part that supercedes the 996 is less likely to introduce the rear end "wiggle" that the original 996 GT3 part did. Does someone have experience with the 997 part on the 996 and improved performance? And if not, does a 997 GT3 have the same "wiggle" as the 996 GT3 - I thought not, but want to confirm.
Old 05-30-2015, 04:47 PM
Gadsby
Gadsby's Avatar
You need to adjust the rear toe setting so that it is toe'd in slightly. You can adjust this with the eccentric with in stock setup or if you go to aftermarket monoball toe links also you can replace the eccentric with lockout bolt. The hardware is the same, the problem when you have wiggle is the same. Monoball toe link will not deflect changing the rear geometry under load.
Hope this helps.
Old 05-31-2015, 07:02 PM
AP328
AP328's Avatar
Thanks for the feedback.
Old 05-31-2015, 10:31 PM
spiller
spiller's Avatar
strongly suggest a lock out plate if using an aftermarket link like above!
Old 06-01-2015, 12:17 AM
vr4henry
vr4henry's Avatar
+1 don't forget the lockout plates....
Quick Reply: 997 GT3 Rear Toe Link to Replace 996 GT3 Rear Toe Link - Experience Anyone?
