Just got home with my new-to-me 6GT3...couple of issues
the float over time wears a groove into the surface where it swings back and forth with filling the tank. if the tank is constantly filled at 3/4 then the groove stops the needle form going higher when filled. use the mileage counter its more accurate and cheaper than replacing the float assay. recalibration probably won't fix this. its a very common thing on older cars
Josh,
I have a post from a few years ago titled "passenger window not dropping down". Hopefully this might help. Renntech, 996 forum and pelican has how to remove inner door panel. I have a fully functional drivers side regulator. I removed when I gutting my door for racing. I am not sure if they are the same for both sides.
So I just tried this again and the window does not move down when you use either the internal or exterior handle. When I try the handle inside the car, I can hear the motor trying to do something but the window doesn't move down. I don't hear anything (motor) when I try the handle from the outside but the window also doesn't move down.
I will try to gently pushing down the window to see if it moves down a little after I open the door. Assuming I can, then its pretty safe to assume that its the window regulator, right?
Also, looks like the regulators are by side:
* Left: 996-542-075-04
* Right: 996-542-076-04
Thanks!
So happy for you! This is such a sweet car. Really miss it even though I love my 997. The 997 doesn't feel as nimble and responsive...this car was just perfect! Hope you enjoy it (sent you a pm by the way!). Enjoy it and I hope next time I get up to your neck of the woods I'll be able to check it out!
Basic Sponsor
You're going to love your GT3! We have a pretty good article on how to replace the regulator which may assist this project if you're going to DIY. Check out Replacing Your Window Regulator.
996 and GT3 window regulator.
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Basic Sponsor
FYI, the regulator failure is fairly common. My mechanic does a lot of them. for all the things like windows, guages, non-performance stuff, our GT3's are the same as a stock 996 or even boxster - mass produced and prone to failure. Its in all the performance stuff that our cars are VERY different.
Enjoy!
Oh, and my wife and I are some of those daily driver people - she drives it fairly often in traffic to work. Loves every minute of it...
Enjoy!
Bob Saville
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
'07 SPC
'71 914/6 Huey
'04 GT3
Bob Saville
704-395-2975
- Data Analysis & Coaching
- Drivers Gear
- Crew Gear
- Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
Just bought my GT3 August 14th. I know the feeling. This is a wonderful car. Mines had the rear portion of the air box swapped with a fabspeed one. Tonight I put in a standard factory box and the car is now quieter inside and sounds a lot like the 997 GT3 I used to have.
I daily drive my car while the weather holds up. There is nothing else on the roads that gives me the thrill of a GT3.
So congrats!!!!! A lovely car to have!
Regarding the gas issue, read these two threads....
https://rennlist.com/forums/996-gt2-...ferrerid=60251
https://rennlist.com/forums/996-gt2-...in-got-me.html
-Blake
-Blake
-Blake
-Blake
Mine seems to be a gauge or bobber issue...
