Europipe for GT3
Originally posted by rockitman
Point well taken Colm!!! I will be doing the 2 day PDE at Skip Barber in Birmingham this Spring. It will only enhance the perfomance of the europipe that I'm about to get...
BTW:In May you can do back to back begining and advanced courses, if you can swing it it's the way to go, keeps the learning momentum going 4 straight days
Originally posted by ADOGNY
Can you use your own car at the PDE events or do they have to provide you with a 996?
http://www.porschedriving.com
Ordered the EP today, but won't be here in time for the dyno day at AWE 12/22. I may wait to install it when we have some decent weather for me to make the trip to install it at AWE and run a dyno before and after the cat/muffler swap. Stef at EP is very helpful and provided these responses to some of the questions I had asked him...
1) Our 100 cell race cats will not cause a Check Engine Light problem .
We had the original 300 cell GT3 cats chemically analysed . According to this chemical analysis our cats are specially coated for street use . The chemical coating is superior to the coating of regular race cats .
The US GT3 engine is identical to the European GT3 counterpart in terms of Lambda / O2 sensor setup .
You do not need an ECU reprogramming with the new exhaust .
However , an ECU reprogramming will indeed maximize the performance of the exhaust system .
2) The dyno graphs are from 1) stock engine , 2) stock engine with the new
exhaust , stock (not reprogrammed) ECU and stock aircleaner .
Dyno stock pipe: 385.1 PS (Hp)
383 NM Torque
Dyno europipe: 397.7 PS (Hp)
394 NM Torque
In summary: +12 HP, +8 lbs/feet torque
At the wheels before(stock): 278 (PS) Hp
At the wheels after EP: 304 (PS) Hp
That's +26 at the wheels!!! Not to mention the awesome note...
Here's how it looks installed on their demo car in their spotless shop...
383 NM Torque
394 NM Torque
uh...Can someone explain to me how RWHP can increase at a rate greater than, in fact more than double, overall HP from an exhaust upgrade? Wouldn't this require a substantial decrease in powertrain loss, etc...?
I think the numbers don't work, for them to check flywheel hp they must remove the engine and the drive train loss is large. Stock the rwhp is low.
The gain in rwhp with the exhaust compared to stock dose not make sense.
I believe you will gain hp/tq with the exhaust but those figures are no accurate.
Rockit -
I am eager to see how it works out for you. While I agree the numbers do not seem to make sense, your personal experience and seat of the pants analysis will be valuable.
Adam
Adam
Will do...I will question the wheel achievement numbers with Stef to discuss the descrepancy...The crank number at 397 is realistic...however...Either way, I have not seen a finer exhaust that has been made for the GT3, IMO...
The question has been emailed to EP....I will post the reply, so you guys don't lose too much sleep...
I found this
https://rennlist.com/forums/showthre...highlight=rwhp
it shows 351 rwhp which seems good, what is the drive train loss % on these cars.
What ever it is i think your dyno testing of stock rwhp to after market exhaust install will bring you gain and you should see up to 360-370 rwhp with some good under/over the curve gains which is what really will be the seat of the pants difference.
I will buy a GT3 this spring and will also look at doing this exhaust change, I will have to import it from the US, one question i have is can you switch from mph to kh/m manually in the car.
The US model shows only mph for the speedometer guage dial and has a digital reading below it in mph. I am not sure if the digital readout can be changed to kilometers/hour or not...None the less, the dial itself only show's mph. I would think this could be changed by the dealer or yourself, if you could order the parts...
RE: conversion from MPH to KM/H - Haven't done it in my new one but it was easy in my old 996 - I'm assuming you can still do it. It was about as difficult as setting the clock IIRC (in fact, that's how I discovered it ).
