First Porsche
At some point in its life, the M96 was fitted with an LN Engineering IMS Retrofit. I contacted LN Engineering, but the serial number was never registered. The awesome lady I spoke with was able to narrow down possible install date range of Summer/Fall 2012. With that info, it was likely installed around 45,000 miles.
Unfortunately, it's the not the IMS Solution so it will need to be replaced in the future.
That is a beautiful car you got yourself! I would not worry too much about the IMS, for ultimate piece of mind you might go with the IMS Solution but I would "simply" go with a new LN ceramic double bearing at your next clutch change. Better spend your money on good regular maintenance and oil changes. Just my 2c. Enjoy the car with your kids; they grow fast!!
Volkert
Volkert
Nice looking car. I have a soft spot for silver as my dad has a '66 in that color too.
Im with Volkert on the IMS advice and money on mantenance. Mine came with the LN bearing installed about 10k miles ago along with clutch and rms. I will change it out in about 40k with a new clutch and Flywheel.
drive it! It will thank you for it.
Volkert
Volkert
I am driving it as much as I can and enjoying every minute of it!
I just bought my first, new to me, 996 4S from a non-Porsche dealership. The dealership was able to get records for me since they "owned" the car. BTW it is an awesome feeling to finally achieve a 32 year old goal of owning a 911.
Shameful Thread Killer
Welcome. Start your own thread, and give us more info.
Unfortunately, this seems to be a somewhat common practice for installers of the LN kits... I've actually got 2 stickers on my drivers side door. Since my car is a '99 and it's got a M96/-04 engine #(I think the original motors should have a M96 -01 designation) I think it's the second motor in the car. It's possible that both bearings were installed in the current engine as I've got 147,000 mi. on the car - problem is, I'm not sure when the current engine was installed.
