Replacing AOS--Help
Replacing AOS--Help
I am in the process of replacing the Air/Oil Separator on my 2000 C2. The hose from the Changeover Value #1 Intake Resonance Flap to the Intake Resonance Flap Actuator (Circled in blue: See photo) was brittle and broke. Any suggestion on name and/or part number?
The p/n of the vacuum hose is in the same post the photo came from
https://rennlist.com/forums/996-forum/849770-mkii-996-vacuum-line-routing-and-related-components.html
It's a few feet long. Just cut to fit.
I had the same thing happen a while back, mine snapped at the #1 Change over valve right at the U-joint hose. So it was cut about 2" back, I ordered P/N 00004320501 black hose assembly and replaced the entire line due to age and material condition of original. The new line came with enough material to cut or make two lines.
