Sunroof panel help
Sunroof panel help
Hello there,
I am replacing my headliner and have found instructions on how to replace the main part, but I am still unsure as to how to remove the sunroof panel for recovering. Can anyone out there help please?
Thank you
Thank you
Its a little tricky. Open the sunroof a couple inches, then push the interior panel another inch or so towards the back of the car to disengage it from the mechanism. Close the sunroof and move to the tilt position. Push the interior panel back as far as it will go easily. close the sunroof again. Remove the four torx screws (two per side) to remove the exterior panel. Then you will need to slide interior panel forward so it is a couple inches from being closed. In the front corners, there is a little plastic clip that connects the interior panel to the side flaps. Unclip these and you should be able to disengage the panel from the mechanism completely. Once this is loose, you can twist it and remove the interior panel out through the sunroof.
Thanks!!!!
I have the panel out for dent removal, but now when I move activate the "close" sunrooof button the sunroof mechanism will start to close -ie move forward but stops about half way and reverses. doing this in steps makes no difference. problem is the rear holes to attach panel are inside the headliner. The manual hex key does not work at all- took that apart earlier and it appears turning with the hex key looks like trying to drive a worm gear backwards- anyway mine will not turn.
Any ideas? Thanks
Any ideas? Thanks
