996 Forum 1999-2005
Disconnect Battery when charging?
Old 11-03-2016, 08:19 PM
jroswell
jroswell's Avatar
Default Disconnect Battery when charging?
My owners manual (2000 C2 Cab) says to disconnect the battery when using a charger or the alternator could be damaged. Is this for real? I would have to reset my clock, radio presets, radio theft code, etc. - a real pain.
How about for a low amperage charger, say 2 to 5 amps?
Can I use a battery maintainer/tender without disconnecting the battery? I'm going into my 1st New England winter with this car and its already cranking slowly.
Old 11-03-2016, 08:49 PM
Ahsai
Ahsai's Avatar
That should not be necessary for either type of charger.
Old 11-03-2016, 10:59 PM
dan_189
dan_189's Avatar
I dont disconnect the battery for my trickle charger (c-tek).
The official c-tek charger plugs into the cigarette lighter so my theory was if that can charge without it being disconnected then mine can too.
Old 11-03-2016, 11:02 PM
Schnell Gelb
Schnell Gelb's Avatar
OP ,
This may help - read what JFP says:
http://986forum.com/forums/performan...nditioner.html
Ctek Mus 4.3:
Old 11-03-2016, 11:12 PM
dan_189
dan_189's Avatar
I have the same charger wired to my battery (with the c-tek quick release connection).
In Australia the cigarette lighter is off without ignition by design
Quick Reply: Disconnect Battery when charging?
