996 Forum 1999-2005
Dension 500 gateway + bluetooth adapter question
Old 05-03-2016, 07:59 AM
dan_189
dan_189's Avatar
Default Dension 500 gateway + bluetooth adapter question
Hey all,
Anyone with a Dension Gateway 500 use a bluetooth to ipod adapter to stream bluetooth music from you phone to the Dension?
Wonder if it would work if no one has tried?
I have the infamous 2004 MOST system. Was going to get an isimple wired FM unit but I remembered seeing a bluetooth adapter for an ipod Bose dock I had started wonder if it works...
Adapter example:
I have no affiliation with this brand/image below just wanted to use it as an example
Have a few bluetooth setups with my Bose and Yamaha gear and it sounds great.
The newer Dension BT unit has it built in but from my research it only works with the PCM2.
Don't get me wrong maybe ill just suck it up and drive with the window down to hear the engine but unlike over in the US its getting cold here
Old 05-04-2016, 11:19 PM
dan_189
dan_189's Avatar
Bump, i'm guessing no ones tried it
Would be willing to give it a go if the Dension unit wasn't over $500...
Old 05-05-2016, 04:10 PM
vandersmith
vandersmith's Avatar
I use a Dension 500 and a bluetooth adapter.
The one I use is the
Himbox Himbox
routed to a Female Stereo to RCA which plugs into the Dension.
Hassle free for the past 10 months.
The one downside - I'm actually now thinking about ripping out the entire sound system for weight. Would've rather spent that $500 elsewhere.
Old 05-05-2016, 05:57 PM
dan_189
dan_189's Avatar
Thanks vandersmith was hoping someone had used an ipod connection to Bluetooth to keep the signal digital to the amp
Cheers
Old 11-15-2016, 05:03 AM
numbah9
numbah9's Avatar
Apologies for the truly terrible photos, but is anyone able to tell what type of fiber connector is being used here? This is for the CDC in an '03 996 with Bose audio and a CDR230.
I picked up a used Dension Gateway 500 Lite and it didn't come with any cables.
Old 11-15-2016, 10:56 AM
Ahsai
Ahsai's Avatar
Looks like the MOST fiber optic cables. Have you checked with Dension for replacement cables?
Old 11-15-2016, 11:24 AM
numbah9
numbah9's Avatar
I'm trying to do that now. I don't know if it's a "Yazakai" type or the other (Tyco?)
Old 11-15-2016, 02:47 PM
318touring
318touring's Avatar
http://shop.dension.com/en/gw500-optical-kit
Old 11-15-2016, 03:15 PM
numbah9
numbah9's Avatar
Originally Posted by 318touring
Thanks! I'll pick that up. If I had an iPhone, do I need the DIN-to-USB adapter, or can I simply plug the iPhone into the USB port on the Gateway?
Old 11-15-2016, 03:57 PM
dan_189
dan_189's Avatar
Fairly sure you'll need the cable, the usb port if for a usb containing music, it can't read the iphone/ipod directory
Old 11-15-2016, 04:38 PM
318touring
318touring's Avatar
Yup this is correct. I use a bluetooth receiver (plugged into AUX) and stream music from my iPhone directly to it.
Old 11-15-2016, 04:40 PM
dan_189
dan_189's Avatar
No one ever answered if the ipod to Bluetooth connector worked ill have to try it when I get the dension unit
Old 11-15-2016, 07:38 PM
numbah9
numbah9's Avatar
Thanks guys! It is, uh, an expensive cable for what it is..
Old 11-15-2016, 07:43 PM
dan_189
dan_189's Avatar
To be honest the ipod functionality is dated, just use the AUX cable. The only advantage to it is I think you can change tracks with the head unit dial.
Even so its limited as there is no track data.
If you had a PCM2 then you could use the latest dension unit with Bluetooth streaming and track info im in the same boat with the CDR-23.
Dension with aux to Bluetooth is the best option IMO
Old 11-15-2016, 08:06 PM
numbah9
numbah9's Avatar
I need the Dension AUX box, then, right? I have an iPhone 7 so I need to use Apple's stupid lightning-to-aux adapter in order to get a standard 3.5mm jack.. sigh.
Quick Reply: Dension 500 gateway + bluetooth adapter question
