996 Forum 1999-2005
Aux input CDR22 (Do these work ok?)
Old 08-07-2015, 03:33 AM
FR10KER
FR10KER's Avatar
Default Aux input CDR22 (Do these work ok?)
Has anyone tried the Becker / ebay AUX input cables shown below (EBAY).
http://www.ebay.co.uk/itm/191476922546?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I have ordered one so I don't have to keep putting CD's in the auto changer.
My plan is to install that in the Becker CDR22 and then connect my phone playing MP3's and the like.
Do they play OK.
Note: This is my first post and I have tried searching the site
Old 08-07-2015, 04:19 AM
Rubik
Rubik's Avatar
Don't know. But I have to do this. I hear [read] it works.
Old 08-07-2015, 08:35 AM
Chris996
Chris996's Avatar
http://www.discountcarstereo.com/USB-BKR.html
This works on AUX great
Old 08-07-2015, 09:13 AM
Carsly
Carsly's Avatar
I installed the aux-in cable on my CDR-220 in place of the factory CD changer and it works quite well. No hiss, static or distortion playing music or Pandora on my iPhone. Inexpensive and relatively easy to DIY (sliding the head unit out is tricky as there is no wiggle room and it's stuck in there pretty good on my car). Go for it!
Old 08-07-2015, 10:03 AM
Arne Klinge
Arne Klinge's Avatar
Have it on my CDR-220, works great. Cheap quality cable though, no isolation for interference. So my mobile interferes quite a lot with it, normally activate air plane mode when using it.
Old 08-07-2015, 10:31 AM
GDI
GDI's Avatar
I tried the one for the iPhone with a lightning connector. It was a hot mess of loose wires, and caused a tremendous amount of noise - even after adding a ground loop isolator. Here is a thread with more info:
https://rennlist.com/forums/996-foru...pointment.html
Fortunately, Beckersound was quick to refund upon return.
Old 08-07-2015, 01:49 PM
white out
white out's Avatar
I've done this on both of my C2's, works well.
Old 08-15-2015, 07:40 PM
FR10KER
FR10KER's Avatar
OK - Got the lead and tried it it works but when I power my Galaxy s5 from the 12v (car) power I get ground effect whine.
I have ordered a 3.5mm eliminator.
Oh yes and using one of these leads you need to enable the aux which is done by pressing the TP button and holding until you see becker then you scroll trough the options till you see AUX and switch it on.
I tried several ferrite cores on the power line which nearly eliminated the while but I will try the signal noise eliminator and test.
Old 08-16-2015, 11:37 AM
sjg1138
sjg1138's Avatar
It works great. I went one step further and installed a bluetooth adapter using the Aux input. Now I can stream from my phone without even plugging it in.
Old 08-16-2015, 12:03 PM
FR10KER
FR10KER's Avatar
Any chance of a link to the Blue tooth adapter?
Old 08-16-2015, 01:15 PM
sjg1138
sjg1138's Avatar
This This
bluetooth adapter is the one I'm using. It looks like there are
better ones better ones
available now.
I also installed a dual usb power supply to provide the Bluetooth adapter with power and to give me a usb charger for my phone. If I find the link I'll post it - it was harder to find than I expected.
Quick Reply: Aux input CDR22 (Do these work ok?)
