996 Forum 1999-2005
anything else I need when replacing A/C condensers?
Old 05-25-2015, 10:38 AM
hazchem88
hazchem88's Avatar
Default anything else I need when replacing A/C condensers?
any other spares I need when replacing A/C condensers?
- what else should I order other than new condensers to replace my rotten ones?
like O rings, or some other parts?
thanks
Old 05-25-2015, 12:21 PM
Macster
Macster's Avatar
thanks
Generally speaking any o-rings or seals that you disturb.
Be sure the mounting hardware and brackets etc are in good condition. You do not want the new condensers flopping about.
Be sure the radiator ducts are clean. It was probably the build up of trash that caused the condensers to become "rotten". (BTW, if the condensers are rotten how do the radiators look?)
The A/C shop where you have the system evacuated to remove any moisture and check for leaks then refilled with refrigerant will or should know how much compressor oil to add to the system to make up for the oil that was lost by the replacement of the condensers.
Old 05-25-2015, 01:33 PM
Schnell Gelb
Schnell Gelb's Avatar
see below
Old 05-25-2015, 01:41 PM
Schnell Gelb
Don't forget to 'wet' the "O" rings with refrigerant oil.
The near side a/c condenser fitting has one 6mm internal hex bolt that requires a very short head on the hex key. A ball-end may help.
Removing the bumper cover: I found it easier to remove the all the fasteners from the front of the wheel-well liner. Use WD-40 or similar to lube the pull-out pin in the plastic fastener otherwise you'll snap it.
This allows much easier access to the one difficult access screw at the trailing ,upper edge of the bumper cover.
It is a great time to relocate your emergency frunk release cable also.
Old 05-25-2015, 02:22 PM
griffiths
griffiths's Avatar
If you have not purchased a new 'drier' ,,, get one.
Insure you have 2 #6 o-rings for it.
And, when you have the system recharged advise
the tech to inject replacement refrigerant oil, PAG 46,
to make up for what was lost, 3 ounces should be sufficient.
http://griffiths.com/product-categor...6-987-996-997/
Old 05-26-2015, 10:27 AM
hazchem88
hazchem88's Avatar
really appreciate all the info, thanks
Old 05-26-2015, 01:27 PM
Macster
Macster's Avatar
The factory manual for my 996 Turbo states 40 cubic centimeters of oil (20 per condenser) needs to be added to make up that which was lost to the replacement of the condensers. That works out to 1.35 ounces. Maybe the 996 condensers take more oil with them when replaced.
To the OP: You or the shop needs to know how much oil to replace. Maybe you can check with you local Porsche dealer parts department and this can be looked up?
Quick Reply: anything else I need when replacing A/C condensers?
