Siphon gas from a 996?
How much is in there? Is drive/idle until empty an option? If not, you can probably snake some 1/4 inch pvc tubing down there and let it out.
Read a post here once that the 996 has a diaphragm or something of the sort in the filler tube. The post had something to do with NOT being able to get fuel in the car at all. May want to check there, sorry didn't save it. But given your location I'd blast around Mosport a few times. The back straight always emptied my tank!
Received 1,091 Likes
Access the top of the tank and fuel pump. Disconnect the fuel line and attach a separate hose. Turn the ignition to on but not to start so the fuel pump runs. Catch fuel in a suitable container and dispose of properly.
