996 engine rattle noise at cold start
I have a 1999 911 Carrera Coupe and at cold start it makes kind of a rattle noise, plus engine ticking for about 10 seconds. My coolant and oil levels are good. The rattle right after ignition start is brand-new and a bit worrisome. Thanks for you help!
Usually that is a sign of chain rattle in my experience not necessarily with the M96 specifically however. Often can mean a worn or broken chain guide. On some motors that is not a big deal ad doesn't need to be immediately addressed. Not sure about how the M96 fits in that area however.
May just take a a short time for hydraulic lifters to fill. GT3 sometimes sounds like end of world for a 5-8 seconds on cold start up.
that's the other thing it could be. If it does it less after a fresh oil change, likely lifters. If no change at all could point to chain guides, but still could be lifters too.
For the rattle, have you checked your exhaust system?
Try this... Pull fuse C4 (fuel pump), spin the engine over for 10 seconds or so - you can even watch for the oil pressure gauge to rise, put the fuse back in and see if it cranks quitter.
On mine its the bank 4-6 chain tensioner that hangs upside down and leaks down after a few hours. I bought all three but that one is the hardest one left to replace on my 01 C2.
Range Master
Pepsie Lite
Pepsie Lite
my engine "rattle" rather a raspy sound, at 125k was a water pump.
while in there, did belt, pulleys, rollers, coil packs and plugs (they were due).
Range Master
Pepsie Lite
Pepsie Lite
I mean I could repeat the stuff about the possibility of the oil being overdue to be changed and cover the issues about selecting the wrong oil -- not that you have I'm just saying sometimes owners come here with weird ideas about what oil to run (5w-30 or something like that...) -- and how these engines are just a bit noisy etc., but I think you should have this listened to by a tech.
I'm even going to be a bit more conservative and advise you flat bed the car to a tech for a listen. I know, I know, but I'm just not willing to risk thousands of dollars unnecessarily to save a hundred bucks.
Of course it is up to you. Oh, and whatever you decide at least avoid the temptation to recreate the noise again and again and have every neighbor give a listen, unless your favorite trusted tech is your neighbor.
The next oil change I did was with Mobil 1 (a 15W-50 and 20W-50 blend). The ticking was gone for about 1500 miles but then came back. My guess was it must be lifter related and you're the first person I've heard with similar experience.
My 1999 996.1 has a rattle, knock, tick during a cold start. 48,000 miles, 0W-40 Mobil 1, 30F outside. Sometimes it sounds like a rod knock, sometimes a chain rattle. Here's a video from yesterday: http://www.youtube.com/watch?v=Z5IrhKTYEcc
stevensctt (05-26-2021)
It is a little disconcerting that so many of these 911s sound the way they do when cold. A lot of folks say that these noises are "common," but that doesn't mean that common is "normal."
I'll do that and also disconnect the belt - as Macster has said in other posts.
Thank you!
My car is currently at shop getting new clutch (including flywheel), AOS, redesigned RMS, EPS IMSB solution.
I pick it up tomorrow. I told him to look into this noise at startup for me while he has it. I'll let you know what he finds.
If my shop doesn't figure it out, I'm changing the water pump myself in the next week or so. I'll know then if it was the slight play in my water pump for sure pulley then.
