Brake light issues
Brake light issues
I assume the switch is failing. When I initially depress the brake pedal or press lightly my brake lights work. As soon as I press harder the go out. On immediate firm braking I get an initial flash of brake lights the nothing. No abs light on dash. Anything else to look for?
Whether you replace this yourself, or have it done -- my local dealer service department replaces the switch for free as long as I buy the switch at the dealer's parts department (the service department also offers this free installation for light bulbs and fuses/relays and wipers) -- my advice would be to replace not only the brake light switch, but the clutch interlock switch (the switch that prevents the engine from cranking if the clutch pedal is not depressed) at least.
I would advise you to also consider replacing the switches above the clutch pedal lever and the brake pedal lever that switch off the cruise control when the clutch pedal or brake pedal is depressed.
