View Poll Results: N Rated?
N rated
30
39.47%
Non N rated
45
59.21%
Non N rated in a model that offers N rating
1
1.32%
Where can I get N rated wheel chair tires?!?!?!
0
0%
Voters: 76. You may not vote on this poll
Do you run N rated tires?
Cardigan Millionaire
Just thought I would poll and see here who actually uses N-rated tires and if you think they are worth it. I saw an old thread about N rated tires and whether the op should stick with them, but I was more interested in seeing what the ratio of owners is like.
Also I was wondering how many users have tires that are not an N rated version of a tire that comes in an N rating. Like the PS2 that you can get in N rated or non N rated.
Personally I could care less about the N rating. I care about putting the best tire suited for my driving versus what Porsche approves, as long as it is the proper size, speed rating and load rating I dont worry about the N.
Right now I am running the Pilot Super Sport which has been the best summer tire I have driven on yet and it doesn't have an N rating, earlier this summer I was using a Dunlop Sport Maxx GT which again was an awesome tire that lacked N rating
I have in prior years used the PS2 and bridgestone RE050 in both N rated and non N rated, and the P Zero Rosso in an N rated only, I was able to tell the difference between an N rated and non N rated in the same model, but even the N rated was not as good as other product offered without an N rating imo.
Rocky Mountain High
I am currently running N-spec Michelin PS2s on my C4S. I'm not opposed to trying non N-spec tires. I'd try the Pilot Super Sports if they were manufactured in the appropriate sizes for the C4S, but they aren't at this time. In my opinion, the N-spec PS2 is the best tire I've ever had on the C4S. Until they make the Super Sport in my sizes, I'll keep buying the PS2.
FWIW, I am running a non N-spec tire on my Cayenne in the summer. On that vehicle, I run the Continental ExtremeContact DWS. I have found it to be vastly superior to the OE Continental SportContact 4x4 that came on my vehicle from the factory. I'm running N-spec Michelin Latitude Alpin tires in the winter.
rblad22 (11-29-2021)
Since this is a 996 forum I will assume your C4S uses a VC, Viscous Coupling. Even a relatively small variation in tire circumference front vs rear will cause the VC to unduly stiffen and that might well result in premature failure of driveline components. Chrysler discontinued the F/awd (VC coupling to the rear) T & C minivan since owners would unknowningly install tire chains only on the front. PTO failure results, often in less than 50 miles.
Rocky Mountain High
The 996 C4S does, in fact, use a viscous coupling in the AWD system.
Rocky Mountain High
They aren't N-spec. They certainly are inexpensive compared to PS2s!
Much missed
I have n-spec on the 996 and the Cayenne. I have no idea why I have them on the Cayenne, but the discount tire chain carried them in stock when I needed new shoes.
I believe N-rated tires are specifically designed to match the rear weight bias of the 911.
Tire Rack has a good overview.
http://www.tirerack.com/tires/tirete....jsp?techid=26
I ran the Sumitomo HTRZIII on my old 968 and was very happy with them. Since buying the 996 I have stuck with N-rated Contis.
Excellent idea for a poll/thread! I am the non-N Porsche brand that starts with M.
I would like to try some Nspec M tires again maybe our esteemed sponser TireRack would do a non-N vs. N test on a modern Porsche to show what the differences are.
I ran N spec when my cars were stock. Now that both cars have been lowered, shocks, springs, and other suspension components changed, I don't see any value in getting tires tested with the original car.
If I happen to choose tires that are N spec then fine.
Here's an article on the subject.
http://www.tirerack.com/tires/tirete...jsp?&techid=26
Parts Specialist
this is your answer
You might find the Sumi good and cheap but your car is bias rear weighted and N specs address this issue - If I had a 996 street car I would 100% get N spec tires
my 3.2 I run Toyo R888's $ Conti DW's (not DWS's) so like WTF do I know
Team Owner
+1
I totally believe that this is true, but what it doesn't consider is that the non-N spec tires of the same model meet the same criteria. That is, are there any actual differences besides the "N" stamp on the side of the tire?
