Motor mounts.
10-26-2010, 05:05 PM
Motor mounts.
Anybody have a favorite? I'm replacing mine. I'm not looking for race-car hard, but something firmer than stock would be fun...
10-26-2010, 05:13 PM
Last I looked it appeared to be two manufactuers. Not sure if it was both for the 996 with one set mk1 and the other mk2.
10-26-2010, 05:22 PM
Aren't the choices...stock, solid, and is there something harder than stock but not necessarily for racing?
10-26-2010, 05:45 PM
AddictRennlist Member
You can also use turbo mounts, which are solid rubber and cheaper. A bit more vibration/noise but certainly nowhere near "solid" mounts.
10-26-2010, 08:43 PM
Isn't Turbo mount is hydraulic too?
How about 993 RS mount?
12. 964.375.043.80 Engine Mounts (qty 2)
13. 901.305.311.00 Seat (qty 4)
15 999.025.074.02 Washer (qty 4)
16. 999.025.134.02 Washer (qty 4)
The OEM bolt is 105mm, you will need 120mm for 996.
10-26-2010, 10:12 PM
This is great, thanks. I hadn't even considered Porsche parts. Are the mounts for the 996 GT3 the same as for the Turbo?
10-26-2010, 10:47 PM
Just put on Turbo mounts last weekend. So far, so good. Have not notice much change in noise level. Good bang for the buck...
10-26-2010, 10:52 PM
Quote:
Originally Posted by
FLY996
But still noticeably firmer than stock?
10-26-2010, 10:59 PM
Part # 900.082.118.09 12 x 125mm gr10.9 bolt works
10-26-2010, 11:00 PM
BruceP
Roger that
10-26-2010, 11:08 PM
Gert sells the RS mount and it will fit the 996...
10-26-2010, 11:15 PM
Anybody here running the RS mount?
The reality is that I still commute in this car. There is a point where vibration at idle would get tough to live with in traffic...
10-27-2010, 01:52 AM
BruceP
Bruce,
I used RS mounts on both the C4S and GT3 and I did not experience where vibration at idle.
Michael
10-27-2010, 04:18 AM
How do you diagnose if / when you should change your motor mount ? noise ? vibrations ? leak ?
10-27-2010, 07:38 AM
That's what I'm running, all parts ordered from Gert. A very easy DIY, follow this...
http://p-car.com/diy/motormount/ It's for a 993 but works pretty much the same.
Makes the shifting and power delivery more precise, hardly any increase in cabin vibration. A very worth while mod for that performance feel...
