FS: 993 K24 Billet Turbos
You will need 5 bar fuel pressure regulator, which I can include with the turbos and a tune from a tuner of your choice.
I'm really starting to look for new or rebuilded profesionaly turbos. I have (k24) as they leak through the turbine/compressor seals even with the turbo check valves I have installed.
EDIT: Is this the company that did the work on your turbos?
How exactly includes a tune from a tuner of our choice? That means is covered the tune by sending the DME to get a reflash so it works best with current setup and these turbos?
You misunderstood my wording a bit, perhaps my grammar wasn't fully clear. I meant I can only include FPR, not the tune. Was just specifying what else will be needed.
