FD Motorsport Transmission Mount
I have the FVD SSK but my brother on his C4S has the FD SSK + Golden Rod with OEM clutch. No gear noise like mine but noticeable mechanical feel improvements on his too. Similar for him, he claims the Fister 3 now sounds like say a Fister 3.5 in the cabin. We concluded the other interior NVH could be attributed to say your suspension setup. The more harsher items like thicker sway bars, coilovers, upgraded susp bushings etc will add more overall vibration feel which just translates to more NVH. In our cases motor sounds too.
I've removed most compliance, from the suspension, shift assm, motor mounts, and have susp. pretty stiff. Again, NVH is not such an annoyance, that I regret it. Bad roads suck, but not because of the car, but because the road sucks :-)
I can't speak to the FD piece. I love those guys and their stuff so I'm sure it's top notch.
FWIW, I put in a semi-solid mount "while I was in there". Light weight flywheel, lsd, RS clutch, at the time JIc suspension.
The NVH is subjective:
On the plus side it sounded like an orgy of angels all having an orgasm at the same time on WOT.
Shifting a little nicer. Not much.
On the downside, in 6th on the road my wife and I could not have a conversation without raising our voices significantly. When the AC came on the whole car changed in vibration. I'm talking every time the AC clutch engaged.
Street / track use...I took it out.
Andy
