Cleaning Aluminum Cases
RL Technical Advisor
JMHO,
Never, absolutely never ever use any abrasive media, aside from soda, to clean engine cases. Soda is water soluble and washes out very nicely with hot water.
Glass beads, flap wheels, walnut shells, plastic,.....any of that stuff spells disaster if any residue is left behind in the cleaning process and its VERY difficult to get all of it out of all the passages in the case.
Use dry ice. I believe that will work best. Basically frozen CO2 at minus 170 deg. F. In a media blast application. On impact dry ice expands and cleans/removes all contaminants including paint. This process works even better if the delta T case-blast media can be increased (heated case). No secondary contaminants Steve Weiner is concerned about. You might find a local guy that does it for you. I've used this application to perform TPM on equipment and machinery and had great success. Google "Cold Jet".
Another alternative would be an acid wash similar to cleaning aluminum rims.
Best, Andre
Best, Andre
A Harbor Freight soda blaster and water makes a nice "do it at home kit" for engine/trans cases.
Be prepared to wear a respiratory filter of some sort as there will be a lot of bicarbonate dust around.
Make sure your garage door is closed unless you want bicarb all over everything.
Your driveway will wash off as nicely as the workpiece with water, make sure to flush all the galleries.
Personally, for engine case I also use a Stomski squirter blasting tool to blow out and test piston squirters and R&R the case plugs with a slide hammer & press to flush completely.
