door light flash issue
Hi,
Do you know what will casue the door light delay flashing.
This happen to my 993, when i use the key to lock the car, the door light will only flashing after almost 8 - 10 second. Is it due to low battery.
Thanks for help.
Thanks for help.
What year is your car?
Why use the key?
Delay ma be part of the delay sequence used to program the key fobs when you do not have a working fob. The sequence involves locking and unlocking the car that starts a sequence with a time out involved.
May also be a delay associated with the ignition immobilizer.
Probably normal if it does it consistently.
Does everything else work properly?
Andy
Why use the key?
Andy
It was 1996 car, she don't come with FOB key. Just normal key. Lock and unlock by manual.
Previous when i use the key to lock the car, The light on door will flashing immdly.
Except recently i notice the door light flashing delay when i lock the door. But everything working as usual. Any thought ?
I have noticed variability in the door flashing. The only things I can think of is that the battery voltage is a little low or the device that controls flashing uses an electrolitic capacitor to trigger the flash and it has dried out a little
It seems that everything works as it should. I wouldn't labor over it. If you had double flashing door top lights, that would be a different story.
If it ain't broke...
Bulbs all good in frunk, interior, and engine bay. Open either door, one chime...then nothing.
Ideas?
What about glovebox light? Also door, frunk, clutch, and engine bay micro switches?
I read about it in this thread:
https://rennlist.com/forums/993-foru...is-locked.html
In Post #10 STLPCA describes the issue and fix.
I have the original radio and there was a piece of tape or paper that had
dried up and disappeared. As a result I had the double flash. I put a small
piece of electrical tape where the old tape was and the problem was solved.
Before:
After:
-bruce
Last edited by bruce7; 05-30-2016 at 03:37 PM. Reason: added photos of where to put the tape
