Fabspeed Cat Bypass pipe question
I'm running the Fabspeed x-pipe with sport cats and am thinking about swapping out the cats with the by-pass pipes for an upcoming track weekend to try them out. For those that run the by-pass pipes instead of CATS, what have you done with the outer O2 sensor? Leave the plug in the pipe and zip tie the sensor out of the way, or install the sensor in the pipe? Since it's a track session not too concerned with throwing a CEL.
Thanks!
Thanks!
That's the direction I went. Left the O2 sensors in the Cats and just ran the by-pass pipes with the plugs in. Took a short test drive and no CEL.....yet. Will be interesting to see how long it takes to throw one.
The by-pass pipes with SuperCups is very loud. Good thing the tracks here don't have db restrictions.
Former Vendor
For off-road purposes, you can program the ECU to work without these O2 sensors in the mapping.
You won't get a CEL either.
It's like a ROW conversion to the ECU and gives you better performance.
Former Vendor
Hence why this is only for off-road and track purposes.
thanks, that is interesting.
I thought the 2nd set of o2 sensors only checked catalytic efficiency and did not make any adjustments.
just sent a cel light when the cats didn't work.
