CCU Schematic
I think that's just the wiring diagram of the whole HVAC system. I think the OP was looking for the electronics layout of the CCU itself, for troubleshooting and/or repair.
Myself and others have done extensive work to find the CCU schematics, but have not yet been able to get it. This is the same situation as the other Porsche electronic units. The vendors are probably not allowed to disclose them due to their contract with Porsche, and most often does not have them at all. I'll send you a bottle of Champagne if you manage to get the schematics.
Could I ask why do you need it?
Cheers,
Tore
Cheers,
Tore
Hi Tore
yes a couple of things seem wacky
- the CCU internal fan is always running
- the heater is always blowing heat from fan setting 2,3,4
- when the fan is set to blue or cold the front fans run at radical speeds blowing hot air
heres the spooky part, when everything is shut down there is a light rubbing sound coming from the front
I disconnect all HVAC motors, opened the footwells and removed the motors checked them both and cleaned them, they are all good
BUT when the motors are plugged in there is a varying voltage going to all of them. this is what is causes the noise, the motors are getting a varying voltage all the time, even when the the key is out of the ignition, but not the flaps don't move
I exchanged face plate with another and the voltage to the motors seems to stop, but the CCU internal fan keeps running
here are some pics
here are some pics
You have at least two problems: A bad T1 transistor, and the servo you have pictured needs to be changed.
Cheers,
Tore
Cheers,
Tore
Hi.
My internal teperature sensor of the CCU is showing the wrong value.
59°C at 19°C.
When I am cross changing the front with the buttons to a working CCU the failure is moving with it.
So the failure is not in the CCU itself it is in the front plate with the buttons and potentiometer.
Who knows on which pins of the flat cable are the relevant resistor values for the internal temperature?
regards
Peter
59°C at 19°C.
regards
Peter
