Rothsport
#31
Guys a serious question:
Why should i put a valve in a system that, in general, doesn't need one*, or has a very minor effect when on the other hand something unexpected stupid but possible happened with it, It would create the risk of blowing the engine?
*) as proven by thousands of other 911, still running without one
#32
#33
Some vehicles spit alot more smoke than others, especially those with rebuilt engines that use after-market pistons and ring packages. Most of the engines I have seen over the years that use JE or other designs tend to blow quite a bit of smoke if they have sat for a while.
When ever you burn anything but an air/fuel mixture in the combustion chamber like oil there is increased likelihood of carbon build up on the pistons and head surfaces reducing combustion efficiencies. For me I would like to make sure that all that is burnt in the cylinders is clean air and as clean fuel as I can find.
Also if there is a large amount of seepage the car can be alot harder to start from cold as you also have to heat then ignite the oil in the cylinder.
Lastly, thinking out loud here and have never seen it nor heard of it. There could be a possibility of hydrolock, the compressed volume of a cylinder is quite small (roughly 55cc) lf you have more 55 cc of oil in there or more then try to start the car you run the chance of engine damage. Now this is highly unlikely with most members vehicles but could happen.
#34
Another question ...
is this valve relevant at all?
my 3.2 is sitting in his garage since 30 years and gets a run-out every 4 to 7 month when i'm back in Germany. In short, open Garage - disconnect cetek - turn key - run it for 1 to 2 weeks - service when adequate - back in the garage - connect cetek - rest for 4 to 7 month. repeat next year ... worked all the time
at first run smokes a little ones in a while for a minute ... no harm
again, such valve ... what for ?!
seems to be the same waste of money like ceramic coating spray for exhaust and mufflers
I'm happy you are thinking about this and your questions are very valid.
My only point was at the Rothsport price point, it was nothing less than a grab your ankles for our simplistic solution aftermarket check valve fellas. I pointed out a viable alternative exists, for a might less schtanging.
CCPCoatings produced and posted test data (albeit somewhat lacking in procedure and parameter definition) on their spray on ceramic coating product, and from what I could tell, looked very good as a heat barrier. However, they are not selling us exhaust systems with the option of ceramic coating for 2 bills.
Other vendors that offer a different spray on ceramic coating for $200; did not. Draw your own conclusions.
If you follow my logic that not all products produce the same results, we'd all be using any/every oil on the market, with the same results.
Segway into yet another oil thread
#35
Holger,
#36
Gee Matt, that was a terrific addition to the, if you don't like the price, there are much more cost effective alternatives.
Thank you for your insight; otherwise that thought would have completely escaped me.
I'm gonna order a dozen and send them out as gifts!
Whats your address? I owe you one!
I don't think life is absurd. I think we are all here for a huge purpose. I think we shrink from the immensity of the purpose we are here for.
#37
Seared
I take my time when changing the oil and never overfill. The car has now covered more than 33,000 miles under my ownership and is as rock solid and dead reliable as ever.
Andreas
#38
Duhhh...I dont?
Nice quote...Does it hold any meaning for you; or did you just think the words sounded good? BTW, there is an unnecessary preposition at the end of the quote (for). Send a note to Norman, will ya?
#39
nine9six,
I received your nice PM, and I might respond either in this thread or privately. However, I respectfully suggest that you go back and re-read what I wrote, for the answers to your questions lie in my posts, or they can be easily inferred with simple logic and deduction. I hope you can maintain objectivity as you go through this thread.
For someone who is done with a thread, you sure do like to keep on coming back.
#40
nine9six,
I received your nice PM, and I might respond either in this thread or privately. However, I respectfully suggest that you to go back and re-read what I wrote, for the answers to your questions lie in my posts or they can be easily inferred with simple logic and deduction. I hope you can maintain objectivity as you go through this thread.
Were discussing a little used up to $300 part…wow.
#42
IMHO, in doing a little "R&D" to make yourself a valve, if the pressure pump cavitates due to a supply restriction by your R&D project that could evolve to a catastrophe costing more than $299.
Everything I have bought so far from Gamroth has been perfect and that has a price.
