Replace foglight bulbs on Euro style bumper?
The PO of my 993 installed Euro bumpers and wired the foglights to the main headlights, and one of the fogs is out, so I need to replace it. Before I start poking around there on how to access them, I'm wondering if it's an easy job (i.e. from inside the frunk) or something that requires the car be on a lift or stands (which means I take it to my mechanic)? Attached is a photo of the bumper.
Thanks in advance!
BT
Thanks in advance!
BT
Received 5,388 Likes
Remove screw from clear corner. Remove corner. Remove screw holding in the Turbo S scoop. Replace light. Done. 5 minutes.
And I like using that bulb grease when replacing automotive bulbs.
Attention: If you've never removed the clear corners before, be careful. After you remove the one screw on the side, don't pull your clear corner outward. You will break the tabs inside. Pull unit towards the front of the car, away from bumper.
Thanks P-daddy re the tabs gotcha.
I should be good on blinker fluid but will check again. Topped it off last time I changed the headlight diffraction grating.
BT
BT
Can someone please help me identify this foglight part, and also, does the part come further apart, i.e. to get to the bulbs? There is a small tab on it but I don't want to break it if it's not supposed to open.
Thanks!
BT
Thanks!
BT
The light unit simply snaps open. There are new Hela units available with 16 LED lights FYI. A good match if you have HID headlights. See the link below for more pictures and details on the Hela lights. It's all pretty easy stuff, good luck!
https://rennlist.com/forums/993-foru...installed.html
Not to start a new topic, but what's the procedure for removing the fog light from US bumper? Need to replace the parking light. BTW, what's the right bulb number for that?
nile13, check out my post on installing turbo scoops for write-up and pictures on the removal process. https://rennlist.com/forums/993-foru...installed.html
Now I need to figure what bulb is used for parking light.
