Interstate MTP-91/T6 Venting
I purchased an Interstate MTP-91/T6 battery to replace the Interstate MTP-91 that came with my car. The old battery utilized the vent kit adapter that attached to the center of the battery. The new MTP-91/T6 does not have a center connection point, but has holes on either side for the vent connection.
How does the vent tube connect to the MTP-91/T6? Is there a fitting that will need to be ordered? The barbed connector that came with the old vent kit does not fit properly.
Any help and/or pictures that can be provided is appreciated.
Find anything that is an interference fit in the side, then go to auto parts store and find a barbed 90 degree fitting. Some are "stepped" and you can just cut it to diameter.
I actually used a drip irrigation 90 that worked perfectly
Thank you for your suggestion. I thought Interstate would have an adapter that wouldn't require a make-shift connection. I'll look through my irrigation parts to see if I can find something that will work.
I used a air hose plastic Tee and some fish tank air hose to each end of the battery
