Heating A/C Fresh air flap motor repair kits
Can this be true:
http://www.partisan-autoteile.de/epa...ellmotoren_993
Actuators 993/964
These servo motors are overhauled , that is, All wear parts are replaced with new parts from quality modern automotive production .
The sliding contacts are hard gold plated . The electric motors are OEM original parts
We check each refurbished servo on an automated test and provide a warranty of two years .
Delivery will be made in exchange for a defective old part
Actuators 993/964
Mr Sattler at PARTisan does this very good, I have exchanged a lot of servos there. As far as I know is he the only one that refurbish these servos.
Other Rennlisters has also used his services, search for his company name here on the forum .
Cheers,
Tore
Cheers,
Tore
Great info!
Can the existing servo motors be serviced (DIY) to prolong their life by cleaning the internals, checking soldered connections and re-grease? And if so what grease is recommended?
The most common fault in these is that the servo motor brushes wear and eventually causes a short circuit, which again causes damage to the PCB end switches due to the excessive current. The motors are not serviceable. (small, difficult to open, and brushes cannot be changed)
Cheers,
Tore
Cheers,
Tore
I was actually referring to the limit switch/PCB inside the housing. Could dirt build up, (cracked or loose) solder gone bad etc. add to a shorter life of the Servo's?
Cheers
jo-hans...
Here is some additional reading for you in case you didn't know about Tore and his in-depth knowledge on the subject of HVAC, and servos...
http://www.porschehvac.bergvill.com/
...And in case you need more...
https://rennlist.com/forums/993-foru...e-history.html
Good to see this link. I swapped my driver and passenger side footwell flaps a couple years back to get working heat on the driver's side. I'm sure total failure is in my near future. Costs and shipping to/from US seem in line with the work.
- Dave
(first post in a long time, but I'm still here!)
- Dave
jo-hans...
I had issues with a non working servo on my old 993 back in 2011 and solved it by cleaning and re-soldering the connections - so I had been in contact with Tore about that and my CCU issues. It's great to have Tore around!
For some reason I missed the second link you posted so thanks for sharing that.
Cheers,
I recently did a complete overhaul of my A/C system. My fresh air intake servo was fried on the PCB just as Tore said.
I contacted Michael Sattler at Partisan Autotiele about his rebuild service. Michael told me he would sell me a Rebuild Kit. The kit consisted of all his replacement parts including the gold plated PCB, motor, gear and shaft, grease, o-rings, and a 9V battery for testing the servo.
About a 2 on the difficulty scale. If you have basic skills and can follow directions you can rebuild your servo using his kit.
My A/C works just fine now! and finally some fresh air due to my new servo!
The rebuild kit:
The rebuild kit:
Great idea. I need at least one of my servos repaired. How much is the kit?
The rebuild kit:
The rebuild kit:
Kit cost and shipping cost, please?
p.s. Thank you for the photo!
Andy, thanks for the informative thread post!
TIA
