RS Motor mounts
RS Motor mounts
Just got a set of RS motor Mounts and the bolt 900 082 03002 (105MM or 4 1/32 inch) is too short is there another bolt I should have
you have a 993 turbo?
edit: assuming you do... otherwise that is the right part # for the bolt
if not, then there is another issue...
For the turbo engine carrier you want to use this bolt: 900 082 118 09
yes, 105mm is correct. I just measured the ones off a car on the lift - we have the engine partially dropped for a clutch job, so those bolts were being used with a set or RS mounts - not a Turbo, but a C4S (same for all the naturally aspirated cars).
Is the engine jacked up tight up to the mounts? When the nuts are fully tightened, there is not a lot of thread exposed.
Cheers,
Mike
Cheers,
Mike
Cheers,
Mike
Cheers,
Mike
Also make sure you aren't installing the engine mount upside down. The bump side of the main piece should be facing downwards and not upwards. I hope that sentence makes sense...
