Decision this week: accommodate lift?
So my garage is getting a new floor starting next Monday, and while talking to a friend, it dawned on me that perhaps I should consider pouring the slab to accommodate a lift. Any suggestions for the best thing to pre-accommodate a lift?
I can't do one of those multi-level car storage lifts, but just something to get the car off the ground so I can work on it. Thoughts?
Search here, since lifts have been discussed a bunch of times. Search terms: lift, MaxJax, garage concrete floor, scissor lift, garage journal (check this latter website, since it gets mentioned every time someone talks about lifts or garage builds.....its garage ****.).
This is what I did:
https://rennlist.com/forums/993-foru...ssor-lift.html
It works great and was not too hurtful money wise.
If I were to do it again here is the route I would go except I would purchase a mid-rise lift:
http://www.garagejournal.com/forum/s...d.php?t=228116
That would probably run $2k to $3k more than what I spent but IMO the ability to drive straight over the runners daily and not have to deal with a somewhat cumbersome hole would be worth it.
depends on your budget really...I did what coreseller above did, but without the fancy stainless framing of the opening.
Atlas mid rise from Greg Smith eqpt was relitively cheap
Very easy to use, car is off the ground at eyeball height is under 5 minutes. Simply makes basic maintenance on these cars a breeze, awesome for cleaning and detailing also.
Still say it's some of the best Porsche money I ever spent...besides my rennlist membership naturally.
I have the Atlas lift, it has been a great addition to the garage for a pretty reasonable cost. We re installed my engine last night using it. Roll the engine and transmission under, lower the car and bolt it in. (Slightly simplified but you get the idea)
A very good reason to do this before the pour...at least here in SoCal, they are using tensioned slabs with high tension cables running through the concrete on a grid, so you can't just open up a hole in the floor to put in a scissor lift or randomly drill for bolts in the floor to put in lift. You probably know if this is the case with your soon to be concrete floor...
If a scissors lift, I would do as Magdaddy and some other Rennlisters have done. Its more work, but worth it in the end.
Magdaddy was a huge help when I did mine, thanks again Joe. I'm sure he was starting to get annoyed with all the questions I hit him with.
IMO preplanning before the concrete pour is much less work vs. cutting an existing slab / floor to accommodate, next time I build a place I will be that much wiser
I've used my lift probably 4 times in the past month, very much a worthwhile addition......
