Dim display on CDR 220 radio
The faceplate works fine on another radio so it is the "box".
Any ideas after cleaning contacts?
TIA
TIA
When the faceplate is on the working radio are you looking at it straight on? The 993 angles it upwards in the dash. The faceplate can be recalibrated to be visible at an angle if that's your issue.
D.
D.
You might to try this thread: https://rennlist.com/forums/928-foru...at-a-time.html
I'm sure Jim will be able to help you.
