993 Forum 1995-1998
DIY - Horn Retaining Ring R&R
Old 05-26-2014, 11:29 PM
NYC993
NYC993's Avatar
This was the easiest DIY...I didn't even finish my beer. I had my battery disconnected four couple of hours. No airbags warning lights.
I read about more cost effective fixes (i.e. just sticking something in between), but I got the frame for 65 bux from porsche, since this should fix it for next 15-20 years.
Out of the four rubber rings, the top left was the most worn out and probably causing the horn to go off. Left bottom was showing a bit of wear, but the right ones are ok. I wonder if it has to do with heat from the window when car is parked in the sun.
Old 05-27-2014, 10:34 AM
PRSWILL
PRSWILL's Avatar
Agreed- my car shipped with a bag basket last November- fixed it in 30 minutes! I love this forum- just did the sunroof seals following the tutorial on this site last weekend- very happy with the results!!
You guys Rock!
Old 08-21-2014, 04:12 PM
Norske
Norske's Avatar
Bruce 7. Great thread and wonderful informative pics. FYI, do not try this without the proper T30 Torx screwdriver or long Torx bit. I had the proper size Torx bit but it was too large and short to fit in the holes in the back of the steering wheel. Borrowed a T30 Torx screw driver from a friend, & used a chaanel loc for torque to remove bolts.
Old 08-21-2014, 04:49 PM
bruce7
bruce7's Avatar
Great to hear that you found it useful. Thanks for the feedback. -bruce
Sent from my iPhone using IB AutoGroup
Old 08-21-2014, 07:40 PM
Coloradocurt
Coloradocurt's Avatar
I found a T30 torx bit at NAPA, about 4" long w/ a 3/8th socket drive on the other end. It was about $10 and delievered to the store in one day. That allowed me to do the job without needing to screw around with the ignition switch and turning the steering wheel.
Old 04-06-2016, 03:12 PM
bruce7
bruce7's Avatar
Default Updated with new link to photo album
Google has moved the link for the photo album to here:
https://goo.gl/photos/bEtLfQcKaAbR6o6p7
-bruce7
Old 04-06-2016, 03:24 PM
Turbodan
Turbodan's Avatar
note the 95 part is different from 96 on.
Old 04-07-2016, 08:49 AM
Kika
Kika's Avatar
I used o-rings:
https://m.youtube.com/watch?v=2WqhZaaXL2I
ronnie993tt (10-22-2023)
Old 05-18-2016, 10:23 AM
vickcraw
vickcraw's Avatar
Default Used o-rings for repair to 95 993
I did this repair with the #31 o rings yesterday. Everything seems to be working great. Followed the video above.
Old 03-06-2023, 09:25 PM
Krylow
2nd Gear
Krylow's Avatar
What a great and easy fix. Thank you for posting.
My early 95 993 used a 13mm?? The only difference
Old 03-07-2023, 03:49 PM
ronnie993tt
ronnie993tt's Avatar
Had my guy fix it in 25 minutes with $4 worth of "O" rings from Home Depot. Here ya go...
Old 10-21-2023, 04:37 PM
abiazis
abiazis's Avatar
Did mine today with #31 O-rings Danco brand........easy DIY to save a few hundred bucks.......
Old 10-24-2023, 09:29 PM
IainM
IainM's Avatar
Can you pull >1G lateral without the horn going off?
Quick Reply: DIY - Horn Retaining Ring R&R
