Big power 993 engines
#76
Its a 335 BHP, 280 lbs-ft 3.6 with our own resonance-plenum, ITB intake system, custom (mild) cams, with gently massaged stock heads and OEM pistons. The header/muffler system is our own design as well and uses Motec M84 Engine Management to give complete control and additional resolution to the fueling and timing maps.
Its benign enough that I'm now planning to build one for my own street car.
#77
RL Technical Advisor
#78
I just saw this thread and read all the way through. Very interesting...
Shortly after buying my 993 with 20k miles on it. I felt that the car need more hp. I went with a TPC supercharger. They (TPC) weren't too far from where I lived in Virginia. I spent about $15k for the kit and install. Dyno was 202 at the rear wheels and 322 rwhp after!!! About 20k miles later, the clutch was starting to slip. I pulled the engine and trans and had Mike Bruns rebuild the engine and LSD. They did a great job. I added a lightweight flywheel and heavy duty clutch. The car is great fun!!!!!
By the way, shameless plug, this car is for sale in the classifieds in this Forum. My interests have shifted.
#79
JMHO,....
There are several high-quality, experienced engine builders here in the US who can provide a big HP, reliable engine and I would encourage you to check around.
I would also advise you to make sure everyone's claims are done with the same type of measuring system and if you really want/need big power, be prepared with a realistic budget to do this.
A notable datapoint is Ed Pink's 4.0L build for Singer, which reputedly puts out 390 hp. This is likely close to the upper limit, folks.
http://singervehicledesign.com/4-lit...-lusciousness/
#80
Steve's being humble here. He and Jeff Gamroth are among the best in the business at building high-powered, naturally-aspirated flat 6 engines. I wanted a 3.8L that was first and foremost as reliable as a factory fresh engine, if not moreso. There is no one else I'd trust with my hard-won money in pursuing such a build. While there are plenty of good engine builders in this country, there are few with the combined expertise and class of these gentlemen. And, similar to the Porsche company, these guys never overestimate the horsepower and torque figures of their builds. There is only so much air that can be pushed through these engines which, I understand, gives rise to inherent limitations with natural aspiration. 400 hp engines and above does seem a bit too good to be true. I'm confident time will bear all this out.
What is very clear with these engines, HP is VERY VERY expensive...
#81
It simply takes the correct combination of parts and components to go well over 400 BHP.
Its simply not inexpensive to do this.
#82
Steve, does going with these trick heads necessitate Motec to run and/or higher compression and increased RPM? Or just Motec? Or just compression? Or both?
If so, would these changes detrimentally affect long-term engine durability for those of us that are concerned with durability?
Just wondering ... for a friend. Yeah, that's right ... a friend.
<furtively checks financial statements>
#83
Considering passing Cal smog, would your built engine be preferred in an obdi or obdii car? thanks
#84
Huh. I guess time has already borne this out, then.
Trick heads are required for HP levels over 360 BHP. Motec is needed to take advantage of the increase in airflow at all RPM's. Remember, these heads require different intake, camshafts, and exhaust to make the expenditure worthwhile and those such engines will not be OBD-II compliant.
Engine durability and longevity are most impacted by CR and maximum operating RPM. Keep the CR compatible with pump gasolines and the max RPM under 7300 and it will last as long as the original engine can.
#85
For CA cars, we stick with the original intake system and the Motronic engine management for this express purpose. One simply limits any modifications to cams & displacement.
#86
Hi Josh,
#87
For those of us in CA, is it possible to run ITBs via the stock Motronic for um, "testing" purposes? Then switch to a different engine management system for "off road" use if you catch my drift. Let's assume this would be for an OBD-1 car.
#88
I believe it is, as I discussed this possibility briefly with Steve and Jeff when I visited their shop.
