993 Forum 1995-1998
Fusebox map: which fuse for the radio?
Old 03-20-2011, 04:27 PM
Shaun Leahy
Shaun Leahy's Avatar
Default Fusebox map: which fuse for the radio?
After a rear tyre blowout lamppost collision, got the fromt end fixed and like new; drove away happy then discovered on the motorway that the radio does not work, drat. Fine beforehand.
Probably a fuse, easier than returnign the whole car: so in the the forward fuse box listing, #38 is the fuse for "radio booster" but ......... which fuse is #38? Who knows of a map anywhere detailing which (of the many) fuse in the box is this one? I doubt there another relevant fuse in the rear fuse box
The workshop manual does not show a fusebox map; I could pick them 1 by 1 but there are approx 50 fuses/relays in there. Did you remove this before an upgrades etc. Thanks
Old 03-20-2011, 04:48 PM
deekay911
deekay911's Avatar
the numbers for the fuses are in raised script on the floor of the fuse box. May not be easy to see so take a light to it..
Also - you sure the radio isn't just asking for the CODE...they probably would have disconnected the battery when doing the repair.
Old 03-20-2011, 05:10 PM
Ed Hughes
Ed Hughes's Avatar
Owner's manual should show them too.
Old 03-20-2011, 11:39 PM
haygeebaby
haygeebaby's Avatar
I just lost all sound to my deck. Deck works fine though. Perhaps the amp on it has problems now. It's a PIA to test it.
Was looking at the fuses myself. Yeah - look next to the fuses - the number is written next to them.
Old 03-23-2011, 04:56 PM
Shaun Leahy
Default 993 Fusebox lists, diags, warning, photos
OK. I want to share what I found out here on fuseboxes on my 96 targa (UK radio therefore no code when I unplug battery)
I attach several photos of my front and rear fuse box diagrams and fuse lists from the 2 lids. Used highest possible resolution (font size is set for watchmakers with microscopes. 5 photos: so you can blow them up
1. Radio booster fuse is up fron #38, damn mine was in good order so my radio problem must be elsewhere.
2. Front fusebox: fuse numbers are next to each fuse though you may need glasses.
3 Do NOT take a slim fuse out and examine it over some open wooden flooring! Kinnoral!
4. Rear fusebox lid in my car had 3 screw/nuts keeping it in place. Use a 10mm open spanner instead unless you are into hyena gnaecology. In my car these screw/nuts are attached to the lid so they cannot fall into the engine bay. Unlikely yours is different as the lid has a 964 part number.
Yes I know why do I need a radio when I have a LPMM?
ciao
Shaun
1996 993 targa
Diggalot (02-05-2022)
Old 03-23-2011, 05:20 PM
deekay911
deekay911's Avatar
I never knew the UK radios had no code - are you sure about that?
Old 03-24-2011, 02:37 PM
Shaun Leahy
deekay911
Since 2001 approx I have had a 964 and now a 993. No code ever needed for the radio; I would unclip the neg battery wire when on holiday or topping up the battery, probably 40 tiems over last 10 years : never needed any radio code or know anyone here who does but then I talk more about engines and exhausts than radios.
Ciao
Old 03-24-2011, 02:44 PM
deekay911
deekay911's Avatar
Which radio do you have? It's more of an option by radio than car/country I would think..
I lived in London for years and had a 964 with a Sony radio and it never needed a code, but I always assumed an OEM Porsche radio in the same car would have asked for a code.
Old 03-24-2011, 02:52 PM
Shaun Leahy
deekay911
You could be spot on there... maybe I was lucky not to have OEM radio. Most air-cooled guys I know have non-Oem radios . I do not talk much about radios and I admit I made an assumption there which is defintely wrong if yours is correct. I should not make an *** of myself.
Good luck
Old 03-24-2011, 03:48 PM
deekay911
deekay911's Avatar
At the end of the day, the sound I like hearing in my car is that engine. I wouldn't rush to fix the radio
Old 10-13-2011, 04:39 PM
DIS
DIS's Avatar
Hi
fuses are all numbered next to the fuse. The Radio fuse is 4th from left closest to the windshield.
Don
Old 10-13-2011, 05:17 PM
Chuck W.
Chuck W.'s Avatar
On CDR-210, CD-210, CDR 220 and CD 220 there is a fuse on the back of the radio. I have only found one of these that was ever blown, but it is worth a check.
You can see the red fuse at the lower right hand corner.
Old 07-16-2013, 02:01 PM
Vq-1
Vq-1's Avatar
I am having the same issue. Found fuse 38, it was blown! Replaced it and it blew again!?! Tried a 30 amp fuse blew again(original fuse was a 25 amp fuse). Any input would be apprieciated.
Old 07-16-2013, 03:04 PM
Hoserpilot
Hoserpilot's Avatar
Vq-1,
Mine blew when some of the wiring was exposed on the harness. I have some accessories powered through the harness. An earlier owner did a poor job of the wiring leaving some wires exposed. Pull your radio out and check the wiring. Hopefully it will be a simple cleanup and coverup of your wires.
I have the cdr-210. Ordered the radio removal tools from pelican. Of course I found stacks of them at Walmart a few days later.
Old 07-16-2013, 03:34 PM
Vq-1
Vq-1's Avatar
Thanks for the input!
Quick Reply: Fusebox map: which fuse for the radio?
