Project "Aria" - An Audiophile's Dream 991
#61
Platinum Sponsor
All three amplifiers have multiple integrated cooling fans and our cover panels will be vented to allow for the air to move around a bit in the frunk, which is really no different than the trunk of a sedan. Also, they're designed for an automotive environment, so as long as we don't completely suffocate them there won't be any thermal issues. We've done this same type of install in the boot of R8's, 430's, 458's, etc and have never had an issue.
#62
Platinum Sponsor
Amplifier wiring is the next step in the process. The power distribution is done and all of the signal patch cables are hand-made to length for the best performance.
#64
Platinum Sponsor
The concept for the amplifier rack is to hide both amplifiers under a carpeted floor that looks like a factory piece. That way the boot is still usable if necessary and no one can tell that anything was done at first glance.
We also wanted to have something the client could enjoy visually and show if he desired. With the amplifiers stacked, we essentially built a trim assembly that would hide the wiring and mounting of all of the equipment, but still show the main bodies.
Here's the process of trimming the lower two amplifiers.
After the parts were built we covered the majority in a black vinyl that matched the factory leather interior. Then an Alcantara insert was added with a laser-etched Porsche crest.
#65
BTW - absolutely incredible build. We've got a 7-panel Magnepan front system in our HT driven by Meridian and Mc gear and I think I'd easily sit in this car and enjoy the experience every bit as much. Thank you so much for sharing. First the car, then the personalization! ghl
#68
Platinum Sponsor
We're getting a lot closer to the finished pictures of the amplifier mounting. Now that the bottom layer is done we built a casing for the upper Class-A tweeter amplifier out of birch. There are a few reliefs built with filler for edge seams where we'll split the vinyl and Alcantara the last photo shows a second "Aria by Musicar" badge from laser-etched brushed aluminum.
Up next we'll have the finished amp rack photos and the build on the "stealth" cover.
#69
Platinum Sponsor
The finished rack....
#71
Platinum Sponsor
This one took about half the frunk if you measure from the shortest height. The frunk is 16" deep in the front and 22" at the rear. This whole assembly with the cover was around 8" or so.
#74
My I know why the amps with lights are put inside the frunk instead of putting it at the back (where you put the woofer) - visible from the rear windshield? It may look cooler that way with the lights on
I had same setup for my old 986 boxster, but the amps wasn't put at the back because there was just no space at the back being a mid-engine and conv.
#75
Platinum Sponsor
