What is the optimum oil temp?
Received 5,414 Likes
Flat6 (F6) vs V8, V6, I4, etc. I thought that all the Porsche F6 engines prior to the 9A1 had the same characteristic..i.e. they took an awful long time for the oil temp to come up to speed. I have a 45km drive to work each day and I have noticed that within 5-10kms at most, the oil in my Macan Turbo is up to temp. With my 991 4S, I am almost at work on a cold day before it reaches the same temp. So from an engineering perspective I am curious to understand what is it about this configuration that affects oil warm up so much. Whether it's a F6 thing or the way Porsche has set the engine up and why.
1) Macan engine in the front
2) Macan turbo'd. More heat generation?
3) Does the Macan weigh more?
I'm pretty sure the 9A1 motor has a significantly different thermal management system as compared to the prior 911 motors in the 997.1.
I completely agree with your recommendation, and that's why I always custom order my Porsches. About ten years ago my son worked as a lot boy at a local Porsche dealership, and he told me that almost every Porsche demo driver would push the car hard as soon as it hit the street.
http://www.mototuneusa.com/break_in_secrets.htm
Certain cults would say that the demo driver was doing you a favor
cult
kəlt/Submit
noun
a system of religious veneration and devotion directed toward a particular figure or object.
Other than the fact there is no faith (religious or otherwise) involved (nor veneration, nor devotion), and seat the rings is an independently verifiable and falsifiable theory based on observation (i.e., SCIENCE!) having nothing to do with any particular figure or object, then yes I guess its a cult. kəlt/Submit
noun
But, since you brought it up, it is the factory (a figure) whose manual (an object) people show veneration and devotion, believing their word on faith. So not a word I'd have chosen but it does seem to fit, just not the way you think.
This by the way is what we call a Freudian slip.
Freud·i·an slip
noun
an unintentional error regarded as revealing subconscious feelings.
noun
220 on my C4S when fully warmed up. On track, in sports plus auto up to 270.
BTW, why would the Porsche engineers not provides with a real temp for coolant on our gage? My understanding is that it defaults to 194 for a wide range.
cult
kəlt/Submit
noun
noun
Freud·i·an slip
noun
noun
Your analysis is a bit overwrought. School of Thought/Cult whatever you want to call it...there are some people that disregard the owners manual's suggestion of low-rpm break-in favor of a high-rpm/high-load breakin. As the science isn't settled as to which method results in better ring seal and/or longevity, proponents of both methods have been seen to argue with what can only be compared with religious fervor.
In fact Mr A. P. from Porsche's GT development group recently spoke about proper engine break in. His recommendation is a modified version of the USA owner's manual. He also advocates an early first oil change at about the 1,000 mile mark.
