93 octane? Californians?
Just purchased my CPO 12 C2S a week and a half ago and filled it up for the first time today. I noticed the fuel door says 93 octane.
What do you californians do that only have 91?
Received 5,413 Likes
They put the 91 in. You're fine. Buy a quality product from a busy station. If you track it some day, buy some unleaded race gas at the track.
I have 93 here in Georgia, I have just never seen 93 as the recommended fuel. its usually 91 because of california. I have a racecar, so if I track it, it will only be one session at some point when I can have my wfie drive the car out, and it wont be all out.
Below is an excerpt from the manual. Basically it says that 93 is ideal but 91 is ok. The engine will accommodate the lower octane without an issue. The lower octane means slightly decreased performance...but if that's all you have in CA, at least you can be reassured that you are doing no damage to the car.
FROM THE MANUAL:
Fuel Recommendations
Your Porsche is equipped with catalytic converters and must use UNLEADED FUEL WITHOUT METALLIC ADDITIVES ONLY.
Your engine is designed to provide optimum performance and fuel economy using unleaded premium fuel with an octane rating of 98 RON (93 CLC or AKI). Porsche therefore recommends the use of these fuels in your vehicle.
Porsche also recognizes that these fuels may not always be available. Be assured that your vehicle will operate properly on unleaded premium fuels with octane numbers of at least 95 RON
(90 CLC or AKI), since the engine’s “Electronic Oktane™ knock control” will adapt the ignition timing, if necessary.
If fuels of less than 95 RON (90 CLC or AKI) are used however, this could reduce performance and increase fuel consumption.
Avoid driving at full throttle.
It is important to observe the regular service intervals, and particularly the oil change intervals, specified in the “Maintenance” booklet.
The use of UNLEADED FUEL ONLY is critically important to the life of the catalytic converters. Deposits from leaded fuels will ruin the converters and make them ineffective as an emission control device.
Cars with catalytic converters have a smaller fuel tank opening, and gas station pumps that dispense unleaded fuel have smaller nozzles. This will prevent accidental pumping of leaded fuel into cars with catalytic converters.
Unleaded fuels may not be available outside the continental U.S. and Canada. Therefore, we recommend you do not take your car to areas or countries where unleaded fuel may not be available.
Octane ratings
Octane rating indicates a fuel’s ability to resist detonation. Therefore, buying the correct octane gas is important to prevent engine “damage”.
The RON octane rating is based on the research method. The CLC (U.S. Cost of Living Council octane rating) or AKI (antiknock index) octane rating usually displayed on U.S. fuel pumps is calculated as research octane number plus motor octane number, divided by 2, that is written as:
The CLC or AKI octane rating is usually lower than the RON rating:
For example: 95 RON equals 90 CLC or AKI.
Fuels containing ethanol
Do not use any fuels containing more than 10 percent ethanol by volume.
We recommend, however, to change to a different fuel or station if any of the following problems occur with your vehicle:
Deterioration of driveability and performance.
Substantially reduced fuel economy.
Vapor lock and non-start problems, especially at high altitude or at high temperature.
Engine malfunction or stalling.
FROM THE MANUAL:
Octane ratings
Can someone explain why higher octane fuel is not available in some parts of the country?
I live in Rancho Santa Fe, CA and we do have some high octane available to us but it is limited and you have to find the correct stations. There is a privately owned Mobil(yuk!) in our town that will sell 100, 95 and 93 Octane. Yes, it is very expensive.
I work for Shell...that's why the "yuk"....lol!
I wonder how much horsepower is lost on a 400 hp 3.8 S engine when the detonation sensors retard the timing with the 91 octane (Research Octane + Motor Octane divided by 2) gasoline in California?
I buy 100 octane (Sunoco brand race gas) at Marks 76 in Fullerton CA.
2043 W Commonwealth Ave, Fullerton, CA 92833
It's $10/gal. I blend in at roughly 1 gal of race gas to 3 gal of 91 to get >93.
I notice a little difference but it may be just the placebo effect. I've been keeping track of mileage vs. the 93 blend and straight up 91, all vs. the 3 different driving modes (in my car) non-sport mode, non-sport mode w/start stop, and sport mode.
I'll post the results probably by end of summer. Start -stop saves a bit of fuel bit I don't like the engine cycling on and off all the time. That causes me worry for long term reliability.
In Toronto we have 93 available but it has ethanol. I just switched to shell 91 because it has no ethanol. So I am trading off higher octane to avoid ethanol. I notice no difference in performance but I don't track the car.I am told I should get better gas mileage but I'm not sure if that is true.
Lifetime Member
Lifetime Member
There are more links at the bottom of the page that might also help you locate sources.
TT
I have used this site to locate 100 unleaded race gas sold at the pump in CA and NV: http://www.davebarton.com/Unleaded_Racing_Fuel_in_SoCal
TT
TT
Can you use commercially available additives (octane boosters, etc) to bring up 91 to 93? Seems easy to buy in bulk and store, and probably is easy to add to the tank, but it is safe? Does it work? And is it legal (the bottles more or less state they are not street legal)
