cooling system fault
Got cooling system fault error, had to tow the car to dealer,apparently there is a problem with valve connecting the system.
Hope its a minor thing?
PS I read a report with Porsche being the leader in reliability based on J.D.Power survey, I was thinking tell me about it.
The valve that failed could be the COV supporting the exhaust, or more simply the vacuum line going to your S or PSE exhaust valves has slipped-off. In either case the "fix" is very straightforward and nothing major.
I had this same issue about a month ago. My SA told me it was related to a problem I had last fall, when I had no heat. Same valve, anyway.
Last fall, there was a national backorder on the valve, so they pulled 1 off a TTS on the lot and gave it to me. This time, they just happened to have 1 in stock, that was ordered in my name. I had my car back in 24 hours.
Good luck and I hope you don't have to wait for the valve.
Just had the same problem fixed on a 2012. All covered under warranty. There was actually no overheating issue and I was able to drive the car for a week before I could get in to get it fixed. Seemed like a valve/vacuum issue.
Just got the yellow cooling system fault message. I don't have PSE but about 20 minutes prior to the warning message my car seemed to sound different/louder.
Think its the "COV" or vacuum line for the exhaust?
I guess I'll call the dealer tomorrow.
I had this issue - was just exhaust related - drove it for a month or so before i had a chance to get it to the dealer to be fixed. They said it was no big deal and common. No PSE for me either.
If not that, then yes, it could be the COV that controls the vacuum pressure to the exhaust valves.
If either of these two as root cause, they are not harming anything and you can drive as much as you'd like until you can get to the dealer.
If this is a common problem, I wonder how much it will cost when its out of warranty. Also, is their "fix" just reattatching it via the same flawed method that causes the "common problem' or is there an actual fix that prevents it from reoccurring?
Once it is out of warranty, I expect the cost to be about $2,500 in parts and 10 hours in labor
My car (2013 991s/PDK....6,200 miles...purchased in March with a CPO) is now in the shop for the THIRD time that this fault has happened. More a PIA than anything else, but I've already told the dealer that I want this noted with the Regional Service Rep and expect this to be resolved permanently.
Being told "this is common" doesn't sit well with me.
so does this mean you can insert a T in the vacuum line and NOT get the cooling system fault message and get a deeper sound coming from your exhaust?
Just wanted to share the resolution. Took my car with this coolant fault to the dealer. Just got it back after 2 days. Receipt states "Replaced faulty hose to valve, rechecked passed smoke test. Also passed vacuum short test."
Yellow fault message is gone and the exhaust sound is back to normal.
Actually there is already a T branching the vacuum line to the two exhaust valves on the S and PSE exhausts. And yes, if you simply cap the exposed end of the vacuum line you will lose the fault warning and your exhaust will sound deeper all the time. This is actually a very easy cheap mod some of us have made and documented in other DIY threads.....
