Complete Porsche 991 GT3 PCCB Brake Option Under One Thread
Former Vendor
If you have PCCB Brakes (Yellow calipers):
Brake Rotors:
Brake Rotors:
PCCB Replacement: CCM Rotors are designed and built by RB 100% compatible with OE calipers and pads
Front & Rear: http://www.racingbrake.com/RB-CCM-Re...por-crk-01.htm
Iron Rotor Conversion: Swap to Iron rotors and save your pccb
Front & Rear: http://www.racingbrake.com/RB-Iron-R...por-irk-03.htm
Brake Pads:Front & Rear: http://www.racingbrake.com/RB-CCM-Re...por-crk-01.htm
For street driving - Low dust, no squeaking XT910 (good for both pccb and iron rotor)
Front:http://www.racingbrake.com/Brake-Pad...pd1768-391.htm
Rear: http://www.racingbrake.com/Brake-Pad...pd1740-391.htm
For tracking - High brake torque XR7 (For iron rotor, for pccb rotor to be announced)
Front: http://www.racingbrake.com/Brake-Pad...pd1768-3r7.htm
Rear: http://www.racingbrake.com/Brake-Pad...pd1740-3r7.htm
Stainless Brake Lines: Replacing stock rubber line and eliminates part of OE rigid lines for easy brake job and improved overall braking performanceCaliper Rebuilding Components: RB’s one solid piece SS piston can resolve OE’s cracked pistons under high heat stress. We also have seal and high temperature boots to improve and extend the serviceability of your OE calipers.Front:http://www.racingbrake.com/Brake-Pad...pd1768-391.htm
Front:http://www.racingbrake.com/SearchRes...nsive_Search=Y
Rear:http://www.racingbrake.com/SearchRes...nsive_Search=Y
Complete RB caliper brake kits for "Plug & Play" Installation:Rear:http://www.racingbrake.com/SearchRes...nsive_Search=Y
Carbon Ceramic Brake Kit: http://www.racingbrake.com/RB-CCB-Sy...ccb-por-01.htm
Iron Rotor Brake Kit: http://www.racingbrake.com/RB-Iron-R...por-irp-10.htm
Last edited by RacingBrake; 05-09-2016 at 02:42 PM. Reason: Links and offer updated
Former Vendor
If you have standard brake (Red calipers)
Brake Rotors: - 100% compatible with OE calipers
Front: http://www.racingbrake.com/Two-piece...-GT-p/2421.htm
Rear: http://www.racingbrake.com/Two-piece...-GT-p/2422.htm
Buy Front and rear kit and save: http://www.racingbrake.com/RB-Iron-R...por-irk-05.htm
Brake Pads:Rear: http://www.racingbrake.com/Two-piece...-GT-p/2422.htm
Front: http://www.racingbrake.com/Brake-Pad...pd1773-391.htm
Front: http://www.racingbrake.com/Brake-Pad...pd1773-3r7.htm
Stainless Brake Lines: Replacing stock rubber line and eliminates part of OE rigid lines for easy brake job and improved overall braking performanceFront: http://www.racingbrake.com/Brake-Pad...pd1773-391.htm
Last edited by RacingBrake; 05-09-2016 at 02:44 PM. Reason: Links and offer updated
Pads and piston links not working for me.
this is very useful.. despite all previous explanations it was difficult for my tiny brain to get straight.
the part about you being able to refinish the ceramics is also a huge value.
Former Vendor
RB is fully committed to CCM brake development beyond street applications. YES - For heavy track application with CCM rotors.
One of the major deficiency we have learned, that's holding the CCM popularity back is finding an adequate brake pad that can withstand the higher heat of a CCM rotor w/o giving up the brake torque consistency (COF) and losing the durability (wear).
This leads us to develop the sintered pad dedicated for this purpose and we are glad to report that based on our final track tests by GT-R and ZR1 track drivers this week, it looks very promising.
Anyone interested in tracking the development and review, comparison with other known compounds can follow this thread in GT-R forum:
In Quest of Ultimate Brake Pad for GT-R..With CCM Rotors
http://www.gtrheritage.com/topic/446...th-ccm-rotors/
The other important criteria to maintain an optimal CCM brake system w/o costing "arms and legs" for discs/rotor replacement is to keep the rotor temperature in check so that we can make sure the rotor is run under 'rotor's threshold temperature which is ~700 deg C w/o causing oxidation which can damage and shorten the rotor life and rising the replacement & re-furbishing which is what deter most track racers.
I found most of the rotor temperature was "guesstimated' by temperature paint (compare the color change), or a hand held IR pyrometer which is not taking the real operating temperature with accuracy in question.
So we are in development of a temperature monitoring system with a thermal couple in constant contact (spring loaded) with rotor surface which is then connected to a digital pyrometer for an accurate temperature readout, peak temp hold, and data collection/analysis.
Anyone interested in this topic can follow this thread in GT-R forum:
Finding an accurate brake temperature for CCM Rotors
http://www.gtrheritage.com/topic/458...or-ccm-rotors/
So 14k for front rotors and another 14k for rears. Wow that seems pricey for ccb. What is the refurbished price for pccb?
Former Vendor
The link for CCM rotors is price for 4 stock size rotors (14K for pccb or 11.5k for std brake converting to CCM)
Please try again for more detail.
Former Vendor
Brake presentation and discussion threads
Ideal Brake Kits for 991 GT3 (9/6/14)
https://rennlist.com/forums/991-gt3/...r-991-gt3.html
Carbon Ceramic Brakes for 991 GT3 (9/8/14)
Iron (Steel) Rotor Replacement for 991 GT3 (9/9/14)
Carbon Ceramic Brakes Package for 991 (non pccb) (12/1/14)
https://rennlist.com/forums/991-gt3/...-non-pccb.html
Replacement Iron Rotors for 991 GT3 (12/4/14)
991 PCCB Replacement rotors are finally here (1/5/15)
https://rennlist.com/forums/991-gt3/...ally-here.html
991 GT3 Iron Rotor Replacement (1/16/15)
https://rennlist.com/forums/991-gt3/...placement.html
CCM Brake Kit for 991 GT3 (Red Caliper) fits 19" Wheels (2/27/15)
https://rennlist.com/forums/991-gt3/...19-wheels.html
380mm Rotor Kit for 19" Wheels (3/12/15)
Caliper Upgrade - A Replacement beyond Rotor and Pad (4/30/15)
https://rennlist.com/forums/991-gt3/...r-and-pad.html
CCM Brake Under 19" Wheels (5/28/15)
What brake pad for PCCB? (7/14/15)
https://rennlist.com/forums/991-gt3/...-for-pccb.html
Former Vendor
Weather you have pccb or standard brake, just looking for brake components replacement or upgrade; from brake pad to the complete system upgrade, we'll have something for you...
Former Vendor
Former Vendor
Updating caliper rebuild thread.
Former Vendor
Complete brake upgrade options for 991 GT3
Links and offer just updated:
https://rennlist.com/forums/991-gt3-...l#post12449859
https://rennlist.com/forums/gt4/9334...l#post13271945
