I will check when I get home
I have not driven it since I picked it up because it continues to F*cking snow here
It would be great to know this. In Germany someone is selling the same solution but states that the lines do not move with the steering angle.
So if yours does I will order it from the US.
Thanks in advance
Hi, do the lines really move when you change the steering angle or are they static?
they are static, but I am going to call the company (CRUX) monday to see if there is a possibility (adjusting the dip switches) to get the lines to move with steering wheel input. Worthwhile nonetheless!
Thank you for your reply. I thought so to that they are static. I was just wondering as you wrote something different in your intial post. I am quite certain that they will not be able to move according to your steering angle, the only thing you can code away are the lines itself.
