GT3 Tools and Gear
#106
Since you have to be putting about 440 ft*lbs on the CL nut, and it's a 4x multiplier, you must be putting 110 ft*lbs in from your torque wrench, and the other 330 ft*lbs must be coming from the reaction bar.
If the reaction bar is, say, 18" long (1.5 ft), and at 45 degrees relative to the floor, then the vertical force from the floor onto the bar (and thus the hub) from the reaction bar interface is (330 ft*lbs) / (1.5 ft) / sin(45 deg) = 311 lbs.
#108
Thanks for the video!
#109
You must have a mechanical eng. degree- thanks for the trig refresh, yes you are right the force on the bar is indeed greater than the amount on the torque wrench. The wrench is 21" from the socket to the end- so more like 133 lbs. force if my math is correct. Not enough to lift the car off the jack by any means but enough to compress the front spring slightly.
I seriously considered one. But if you use a lift, I think dealing with the reaction bar means you have to lower the car back nearly to the ground which may or may not be convenient for some. Pro's and con's for sure.
#110
#112
I'm interested in the best trickle charger for the GT3
http://www.griotsgarage.com/product/...Picks&refType=
or the microprocessor unit for $124.99
#114
I've used these for years with good results:
#115
Mr. Mayor: I'm am fustrated in your lack of response to my PM to list the torque multiplier on your original post. I hope it is an error of ommision and not an editorial on the value of the tools. I have responded to several PM's asking about the tools since my posts above- it would be nice to list it like the others.
#117
also, I never received any PMs.
#118
^Hmm, not sure why you didn't receive the PM, but thanks for posting it.
#119
http://buy1.snapon.com/catalog/item....store&tool=all
For those using a Torque Multiplier, this device measures the torque on the output shaft, eliminating losses and error in the multiplier. 2% accuracy. I don't have one, and it's a little spendy, but it looks like a slick solution, and like a good tools, cry once or cry forever....
#120
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,526 Likes
I suggest that we add aftermarket wheels (OEM sizes and offsets) to the list. Here's what Tire Rack shows:
http://www.tirerack.com/wheels/resul...&package=false
