If I want to play songs off my ipod/iphone, do I need telephone bluetooth module?
I searched and read every thread on this topic, but still unclear. I don't care at all about being able to make phone calls through the car system. Don't care at all about Bluetooth for my phone calls. I do want to be able to play the songs on my ipod and/or iPhone through the car stereo system. On my current configuration I have selected PCM/Nav and the sound plus pkg. There are separate (not inexpensive) options that detail out GSM phone service in the car, Bluetooth, etc. If I don't care about phone and only audio through my ipod/iphone, do I still need those options?
With the universal audio interface (USB) in the glove compartment, you can connect your iPod® or any other compatible audio source of your choice. By means of the USB socket, it is also possible to download data from the performance display of the Sport Chrono Package, as well as data from the electronic logbook. In the opposite direction, you can transfer up to 10,000 tracks in MP3 format to the internal hard drive of PCM and create your own jukebox.
I spoke with my dealer when building out my car.. and it comes with bluetooth as standard.. so you can use phone and play music with no option. The telephone option allows you to use a cellular chip in the car to connect with your provider vs. your phone to save battery (vs. standard bluetooth which just uses your phone to connect to service, but plays through car causing you to use battery as normal). And then there is a telephone option with a handset. Hope this makes sense...
You will be all set to listen to tunes via ipod/iphone , android phone ipad etc.
go on the configurator look on standard features under electrical , as well
pull up the info tab for the PCM there it states universal audio input and usb
input jacks , basically you will need a cable with mini headphone jacks both
ends one into your devise the other into jack in glove box , on my 997.2
there was a plug in in the center arm rest compartment hopefully the same with this new car
perhaps someone who already has the car a verify location of the plug/in jack
thanks everyone...sounds the same as my .2 gt3 then, I just plug into the cords in the center arm compartment. Confusing that there is a separate option for phone. thanks again
Jonathan ,
Why would anyone want to dig their gsm chip out of their ihone to place it in the car?.. Sounds like such a nonsensical and outmoded option.
Glad I read this thread though.. From what I understand now, none of the phone options are necessary at all for an ihone user like myself who uses an earbud set
During my daily commute I have seen folks driving along, painting their nails, reading a book, and yes listening to their tunes through a set of earbuds .... Scary stuff.
Ryan
iPhones (up to 5s at least) don't support rSAP though so, if you have one of them, don't order the Telephone Module unless you are planning to put a SIM in the PCM.
Thanks for the clarity ,I think a lot of confusion due to the 619 BT option
needed on the 14 build or no phony, now a standard function for BT
Have a good week
Deacon
Modern german muscle car. So much displacement. Linear torque everywhere. Sloppy on the road because the rear just breaks free in every gear. So much fun. Not confidence inspiring around the twisties, but as showpiece/presence on the road, and straight line speed, sound, etc. Awesome. Highlight was the engine/exhaust note. Parts bin outlaw type car. If you even have to ask MPG, don't bother.
