Irregular front tire wear
Must not have checked? Did you ever rotate? 4 days on the same track, with an abrasive surface would do that to any tire IMO.
I joke a little, but when we buy new tires for the GT3, it really should be a 5 tire purchase. 3 fronts, 2 rears. The wear and heat cycles will match almost perfectly
IMO, 34lbs hot is too much. I just replaced my tires after. nearly 10k miles, 3 tracks, and 7 track days. They were most likely heat cycled out after 5, but I had nice, even wear.
