Does anyone have any insight on whether or not...
It will be possible to mix seats in the GT3 so that I can have the lightweight bucket for the drivers seat, and the regular sport seat on the passenger side? Obviously it will need to be done after delivery to get this configuration.
If your question is centered around "can it be done physically" then agree with the above ... should work. If your question is centered around "will I have electronic issues with air bags, power modules, etc" then again, probably not if using Porsche seats with correct connectors (may have to reprogram airbag warnings with PIWIS II). If your question is centered around "can I have instructors in my car at the track", then probably not. Most organizations require the same seat (ie safety system) in place for driver and passenger/instructor.
If this last point is of importance to you, then you should most definitely check with your organization's CDI.
I asked this of my dealer and they talked to the Porsche regional technical rep and they said you can switch the seats easily but not the electronics. They said this can only be done at the factory as the wiring, number of wires, etc is unique to each seat type.
You'd have to rewire half the car, rip up the carpet and pull apart the dash, and somehow get wiring and other parts from Germany. My dealer and the technical rep said it could only be done at the factory.
Needless to say, I was not pleased to hear this.
Ryan
Ryan
I hope you are right. To make a long story short, I want to swap my 18-way seats 991 GT3 seats with a fellow 991 GT3 owner who has 4-way seats.
My dealer service manager said it was impossible. He said he spoke with his Regional Porsche technical rep who stated it was impossible outside of the factory, as the wiring harnesses are different and even the amount of wiring was different on the 18 way seats, and you'd have to rip the entire car apart to do it, and get wiring from Germany etc...
Maybe I should just call someone at PCNA, but who ? I don't know how to get a straight answer on this......
How do you know this?
Most of the HPDE sponsoring Organizations and Clubs require identical restraint systems for both passenger and driver. Buckets are usually used with 4,5, or 6 point mounting safety belts.
It would be difficult to provide those restraints with a conventional passenger seat.
I had not considered the HDPE and track implications, thank you for reminding me of that. I was asking due to passengers and lady friends, not wanting to get in and out of the bucket seats and the others being more comfortable for them.
