Final Call - Add RS decals and/or deviated stitching to Signal Green build?
Decals are a must if you've got the opportunity, especially with green. They just look right. As for the stitching, any shade of yellow or green that is not the same as your exterior color will look off, regardless if you are matching to caliper...which let's be honest is reaching anyways. Black seems to make the most sense with your build.
Go with the decals...
I would say no to both - simple is best
your signal green 964 (via RPM) was the first time I saw the color. That was many years ago. Having been drooling over the color ever since.
and to correct myself, the deviated stitching is $5k+, not $9k+, which is the total with the original full leather + deviated stitching
Decals and maybe platinum stitching. I feel the acid green might come off looking like a mismatch.
With signal green, I think it will be hard to add anything that will detract from your unicorn. Go crazy!
Please dont do stitiching unless you can get the same green. Man some of these people that mis match colors, gawd. Green with yellow stitching would be nasty, and in a bad way.
