968 Forum 1992-1995
Excellent VIN decoder
Old 01-10-2011, 04:14 PM
tek_121
tek_121's Avatar
Originally Posted by jeff968
Ha!!! yeah, those digits do make a difference. Looks much better now:
Your car is:
#1,544 of 2,234 NA 968 coupes
#287 of the 718 1994 NA 968 coupes
1 of 220 F8 Midnight Blue NA 968 coupes
1 of 89 F8 MidnightBlue 968 coupes paired with classic gray interior
Factory options include:
TT - partial leather interior in classic gray
XD4 - painted crest center caps
398 - 17" 993 style Cup 2 wheels
437 - full 8 way power driver's seat
Your car is NOT a 718/Model year reVIN 968 so it is a true 1994. You have the 993 style seats and no engine bay trim pieces. I could use your production date (found on the driver's door VIN sticker)
Is that better?
Jeff
That make's way more sense!
I'll give you the year another time, my car is store for the winter, dont have access to it easily...
thanks, very interesting...
Old 01-10-2011, 04:25 PM
Vilhuer
Vilhuer's Avatar
First link uses same factory source as PET 7 to get model and option data. It just tries to explain codes but isn't any better than PET. Both are simply pragrammed wrong and would return much more explanations if code would change leading letter I to M.
Old 01-10-2011, 05:16 PM
JonT
JonT's Avatar
Okay Jon,
Let's see if I do better for you:
You car is:
#1,843 of 2,234 NA 968 coupes
#586 of the 718 1994 NA 968 coupes
1 of 29 D3 Iris Blue NA 968 coupes
1 of 11 D3 Iris Blue 968 coupes paired with midnight blue/marble gray interior
WQ - partial leather interior in midnight blue/marble gray
220 - Limited slip differential
437 - full 8 way power driver's seat (yes this is correct but the owner's manual shows yet another option with three round plus one rocker switch, not sure what that thing would be called).
490 - hi-fi sound speakers w/Amp
595 - Rear spoiler painted body color
Other options on my sticker:
331 -- AM/FM Cassette with 2 door speakers (note though option M490 has the 10 speaker option)
423 -- Cassette container and coin box. Car did not have this when I got it, just an empty bin with lid.
425 -- Read window wiper
454 -- Automatic speed control
650 -- Electric sunroof
09991 - Have seen lots of discussions about this and whether or not all USA cars have this. Exclusive program I believe.
Your car is NOT a 718/Model year reVIN 968 so it is a true 1994. You have the 993 style seats and no engine bay trim pieces. What is your vehicle production date? Dec 93? Jan 94?
Jeff
It is a true 1994 with all the updates, build date Nov 1993. I have a pretty rare piece of documentation called the 1994 MY supplement that lists all the updates from 1993; it's pretty cool.
--UPDATE HERE-- this document is WKD 498 821, which a quick google shows as available at sunset for ten bucks.
http://www.sunsetimports.com/resource/wkd-498-821/
Someone jump on that, I though this was long out of print.
My scanner at home is on the fritz or I'd show you a sample.
By the way, the Iris Blue over midnight blue+marble gray is really stunning, but I'm kinda biased there
Jon
Old 01-10-2011, 05:59 PM
jeff968
jeff968's Avatar
Originally Posted by JonT
Nice shot. Most is correct above except I'm not sure about the 8-way power seat. I don't believe 437 is on the option sticker. I have two round electric switches on the side of the driver's seat, fore/aft and up/down. Not sure what makes an 8-way seat. I did not have a CD changer when I got the car but the Autoatlanta decoder link above lists M595 as rear spoiler painted body color, which I DO have.
I'll dig up the option sticker when I get home and update this.
Jon
Opps, my fault for cutting and pasting. 595 is indeed body colored rear spoiler. 692 is CD changer. As for the power seat it is easy enough to check. Compare your two seat switchess. The driver's should have slightly different controls then the passenger (although both have two switches). A standard 4 way seat has a bar in the front to move the seat forward and backward. To do that with the eight way seat you use the switch. I would love a scan of that document.
Jeff
Old 01-10-2011, 09:32 PM
JonT
JonT's Avatar
See updates in post #18.
Old 01-10-2011, 09:52 PM
jeff968
jeff968's Avatar
Jon,
These are all standard, no extra cost features on the NA 968. I only listed the options. 09991 is there because your car has the Xd4 painted center caps option. XD4 is part of the exclusive program.
Thanks for the document image!
Jeff
Old 01-11-2011, 12:59 AM
LTCMontana
LTCMontana's Avatar
Can I play?
Coupe Build date 3/94 Last 3- 108
Old 01-11-2011, 09:42 AM
jeff968
jeff968's Avatar
Originally Posted by LTCMontana
Can I play?
You sure can.
Your car is:
#2,023 of 2,234 NA 968 coupes
#48 of the 259 1995 NA 968 coupes
1 of 595 A1 Black NA 968 coupes (most popular)
1 of 54 A1 Black 968 coupes paired with classic gray interior
438 - full 8 way power passenger's seat
Your car is a 718/Model year reVIN 968. Is was born a 1994 and changed to a 1995. You have the 993 style seats and no engine bay trim pieces. I'm not listing standard equipment like the cassette player/sunroof, ect.
Jeff
Old 01-11-2011, 10:14 AM
Vilhuer
Vilhuer's Avatar
Made between 03/94 - 08/94. I believe in 968 cases both '94 and '95 M718 early model year production started at March. From legal point of view anything after January 1st was ok to be called next MY car. In any case door sticker in early M718 VIN cars will tell when first of them were made. 0061 was first and 0108 is not too far from it that both couldn't have been made in same month.
Normal '95 MY were done in usual August change point meaning 08/94 - 08/95.
Old 01-11-2011, 11:34 AM
jeff968
jeff968's Avatar
Actually February 1994. There were true "R" 1994 non-718 cars produced in Febraury and then Porsche started with the "S" 1995 718 cars produced in the same month.
Old 01-11-2011, 11:59 AM
Vilhuer
Vilhuer's Avatar
Does your data source have actual build dates or is info based on individual known car door stickers? Not saying you are wrong. Its just interesting to know if there is system where such data could be checked besided fully closed to outsiders Porsche internal databases.
Old 01-11-2011, 02:41 PM
jeff968
jeff968's Avatar
When it comes to production dates, I get the information from the door jam stickers. Example, I assume that if the prod date from the VIN sticker from 968 w VIN 300 is March and 968 w VIN 400 is March then all the cars in between them are also March so I haven't seen them all.
Jeff
Old 01-11-2011, 03:47 PM
User 41221
User 41221's Avatar
Jeff, you've opened the genie's bottle, lets see if you can put it back! lol
1992, Cab #0404
Thanks! ...Scott
Old 01-11-2011, 04:17 PM
PorscheG96
PorscheG96's Avatar
1992, Cab #0404
Thanks! ...Scott
LOL, no kidding! I posted a link I thought was useful for getting options lists for Porsche VIN numbers but I should've posted a link to Jeff instead.
Old 01-11-2011, 05:02 PM
jeff968
jeff968's Avatar
1992, Cab #0404
Thanks! ...Scott
Here you go Scott:
Your car is:
#344 of 2,008 NA 968 cabs
#344 of the 667 1992 NA 968 cabs
1 of 34 F4 Horizon Blue cabs
1 of 16 F4 Horizon Blue tiptronic cabs
1 of 5 F4 Horizon Blue cabs paired with classic gray/light gray interior and a V8 dark blue top
249 - Tiptronic
F4 - Horizon Blue metallic paint
TU - partial leather interior in classic gray/light gray
490/494 - hi-fi sound with Amps
Your car has a November 1991 build and has the recessed hood badge. Do you have the edged rear emblems as well? I'm not listing standard equipment like the 331 cassette player/454 cruise, ect.
Jeff
Quick Reply: Excellent VIN decoder
