964 Turbo Forum 1989-1994
Turbo 3.6 front calipers....same as 993tt?
Old 04-16-2010, 04:38 AM
ttAmerica RoadsterAWD
ttAmerica RoadsterAWD's Avatar
Default Turbo 3.6 front calipers....same as 993tt?
Guys, i'm right in the middle of putting in EVO uprights on my car. It has Big Reds from a 3.6T. The EVO uprights are from 993. Can somebody confirm that the front 3.6T big reds are the same, identical calipers as the 993TT......
Thanks a million.
Jaime
Old 04-16-2010, 09:05 PM
Metal Guru
Metal Guru's Avatar
Yes, they are the same.
Reference info courtesy of Bill Verberg http://members.rennlist.com/1976c38/brakes.htm
Old 04-17-2010, 12:50 AM
Thank you very much!
Old 04-20-2010, 10:28 AM
dunavantent
dunavantent's Avatar
You sure they are the same?? I converted my 91 brakes to 94 brakes. Pads are larger towards the center. Then My friend just bought 993tt brakes but he's using a 993 spindle setup. I haven't measured the 993 brakes.
Old 04-20-2010, 06:44 PM
Miles965uk
Miles965uk's Avatar
I dont think they are.
They have the same size caliper but the 993TT uses more of the rotor depth than the 3.6T.
Old 04-20-2010, 07:12 PM
Metal Guru
Metal Guru's Avatar
The question was are the calipers the same. They are. The 3.6 front caliper was actually first utilized on the 928 GTS. The bleeders and crossover pipe are reversed between the two applications. The same calipers were spec'ed for the 993 TT. None share the same rotors.
Old 04-20-2010, 08:13 PM
LA964RS
LA964RS's Avatar
mine are bolted to my 993 evo uprights w/o any adapter. Do note that you will have to run 993 rotors. At least that's what I put on mine.
Old 04-21-2010, 12:06 AM
dunavantent
I have both cars in my driveway. I'll check tomorrow. Hmmm.... Can I see some more photos of LA964RS??
Old 04-21-2010, 08:15 PM
Metal Guru
Metal Guru's Avatar
Oh, so your gonna pull the calipers off both cars and lay them out to tell us what we already know? Ok then
Old 04-21-2010, 11:30 PM
JamesE
RIP
JamesE's Avatar
Sorry OT: Miles did you get my PM about the gearbox? If not, Im interested....
Old 04-22-2010, 05:16 PM
LA964RS
LA964RS's Avatar
You can find some pics in the 964 section here or read the features in:
Excellence 11/08
Porsche&911 World 4/09
Total 911 Issue #60 (on news stand now)
Old 04-25-2010, 08:49 AM
dunavantent
First, Metal Guru I wasn't talking to you. Second, TTAmerica Roadster would have to switch his Stock 92 turbo Front rotors.
Old 04-25-2010, 09:48 AM
Metal Guru
Metal Guru's Avatar
My point was that all the information is available on the link to Bill Verberg's brake page. Anything and everything that anyone wants to know about calipers and rotor size is there. Also, Bill regularly answers questions about compatibility and is good about answering private messages. There's really no need to disassemble a car to get that info.
Nice car, by the way. Don't sell it.
Over and out...
Old 04-27-2010, 10:59 PM
Guys, at this point I don't know exactly what I've got. My "big reds" calipers will not allow the 993 pads to go in deeper, and in fact, the 993 pad material sticks out away from the surface of the rotor by 1/4 inch. Guess the 965T and 993tt are indeed not identical (Miles965uk summed it up)! There is the distinct possibility perhaps I don't have big reds after all....
Does anybody know where on the calipers are the Porsche numbers? I cant see a 964/965/993 number anywhere
Will need to source some new calipers. Anybody have lightly used 993tt calipers or know of anybody who may have a pair??
Old 04-28-2010, 10:09 AM
cobalt
cobalt's Avatar
Received 2,288 Likes on 1,353 Posts
Unfortunately, the part numbers are applied by a sticker that more than likely has worn off or has been removed.
If 993TT pads don't fit you don't have 993TT, 94 turbo or 928 GTS calipers. Sounds like you might have 91-92 turbo medium S4 calipers. These use a smaller 48 x 132mm pad vs a 58 x 132mm pad so about .395" difference in height.
FYI here is a pic of a 993TT caliper i purchased new. Part number 993.351.425(426).10 same part number as the 94 turbo 3.6 caliper. You might have the 91-92 964 turbo 3.3l caliper part number 965.351.423(424).01 calipers which look similar in black. Both have the same 44/36 pistons. other than the size of the pad it is hard to determine which they are.
The picture below the new caliper is my GTS with same brake in black with switched bleeds and feeds for trailing mount. Lastly the 993TT calipers fitted to my C2 using 94 964T 3.6 adapters and 94 turbo rotor.
Quick Reply: Turbo 3.6 front calipers....same as 993tt?
