Swepco 201 Transmission Fluid ok for LSD
Originally Posted by Y.S
I just replaced mine with Mobil 1 Syn 75W90 and boy do i feel the difference..
No problems whatsoever with Mobil 1, even when backing up and turning at the same time ?
Edit:
I know it's against one of the 10 commandments, but I want your wheels so bad
They are just stunning!
The transmission felt bit lose and it also needed some effort to engage but with mobil 1 it feels much smoother now and takes quite a bit less effort too.The tech changed the oil so can't comment on the washer,sorry ?
Staffan,
I'll post some better picts tomorrow.
Later
Staffan,
Later
Swepco was the ticket in my 911 SC, but the 915 transaxle has the notoriously bad Porsche-designed syncros which needed all the help they could get.
After the failed Delvac experiment, I went to Mobil 1 and I have been very happy with it.
Conventional Swepco 201 is the gold standard for both 915.XX and 930.XX boxes. The Getrag-drived G50.XX boxes, utilizing Borg-Warner double-cone syncros, are better suited with synthetic gear oils.
And while the Mobil 1 75W-90 gear oil you referenced above [found at Walmart or your neighborhood FLAPS] is synthetic, my understanding is that it contains various friction modifiers that don't play as well with the BW syncros or the LSD.
Instead, I suggest you find a local Porsche tuner/race shop that can sell you/service your car with Mobil 1 Delvac or simply purschase it yourself on-line. If you speak with any number of subject matter experts, I suspect they would recomment the Delvac, over the common Mobil 1 75W-90, as well.
For those that prefer other brands, Amsoil, Redline, Royal Purple, and others, also make suitable gear oil for the G50.XX/LSD boxes.
Been there, done that and it was a disaster as well as a waste of money and time.
Delvac does not play well in the G50/52 transaxle with the 20/100 lsd. Delvac is not slippery enough for the diff to work correctly.
I know the guys with G50/50 boxes like it but it doesn't mean it works in a G50/52. Over here, there are a number of "subject matter experts" that will advise against using Delvac.
Do you think the Delvac does not play well with the G50.52 specifically because of its 20% LSD? When you ran Delvac, were you getting unusual/excess chatter in tight turns?
So, if this is the case, then between Delvac and the more easily accessible Mobil 1 75W-90, it would be better to run the 75W-90, correct?
Have you tried any of the Amsoil, Redline, or Royal Purple gear oils? What do you like to run in your box?
Here's what Mobil 1 has to say about it: http://www.mobiloil.com/USA-English/...ransaxles.aspx
My personal experience, as mentioned before, follows this advice.
I've only run Mobil 1 LS. I've heard good things about Amsoil engine oil and Redline power steering fluid but have never tried their gear oils. I put so few miles on my car that I haven't needed to change gear oil since the Delvac/LS change.
