964 Forum 1989-1994
2017 RUF CTR
Old 03-07-2017, 01:36 PM
911Jetta
911Jetta's Avatar
Default 2017 RUF CTR
Not built on a 964 (or 993) tub anymore! Sorry for the off topic thread
World’s First Rear-Engine Carbon Monocoque Road Car
http://www.autoblog.com/2017/03/07/2...#slide-4694864
2017 RUF CTR Unveiled in Geneva
- First RUF car engineered and designed by RUF
- First rear-engine carbon fiber monocoque chassis
- Twin-turbo 3.6L flat-six creates 522 kw (710 PS), 880 Nm (649 lb-ft)
- Rear-engine design sends power to rear wheels through six-speed manual gear box
- Top speed in excess of 360 km/h (223 mph)
- 0-100 km/h (62 mph) in less than 3.5 seconds, 0-200 km/h (124 mph) in less than 9 seconds
Revered sports car manufacturer RUF
Automobile GmbH unveiled the latest generation of its famed CTR halo car today during the 87th Geneva Motor Show. This is the first RUF sports car to be based on a chassis completely of the firm’s own design with a body that pays tribute to the 1987 CTR
“Yellow Bird.”
“The concept for the 2017 CTR is one that I have had in my head for a very long time,” said Alois Ruf, President and owner of RUF Automobile GmbH. “We have been waiting for the right point in our history to build our own car and the 30th anniversary of the CTR
‘Yellow Bird’ is that moment.”
New Chapter in a David and Goliath Story
Entering its fourth generation, the latest high-performance RUF supercar pays homage to the 1987 CTR Yellow Bird in both form and function. A weight-to-power ratio of only 3.5 lbs per horsepower, a first-ever rear-wheel drive bespoke carbon fiber monocoque chassis and an incredibly powerful engine are only some of the ingredients that make the latest CTR such a compelling work of automotive art.
Design inspiration comes directly from the 1987 Yellow Bird’s focus on aerodynamic efficiency. The silhouette, narrow body, rear air inlets and fascias are all direct nods to the company heritage. The body, now formed in carbon, calls back to the original car’s
flushed look.
Center-locking 19-inch forged alloy wheels complete the design wrapped in tires measuring 245/35ZR19 in the front and 305/30ZR19 in the rear.
Powerful, Traditional and Thoroughly Modern
Technological sophistication starts with the skin, which is made completely of carbon fiber. For the first time, the chassis beneath that surface – also made of carbon fiber - is a bespoke monocoque, a proprietary RUF design. The front and rear crash structures are built with lightweight, steel as is the integrated roll cage that are both designed to maximize occupant safety. In total, the extensive use of modern materials allows for an extremely light dry weight of 1,200 kg (2,640 lbs).
Like most RUF works, the 2017 CTR uses a rear-engine powertrain layout. The 3.6-liter twin-turbo flat-six is built by RUF and inspired by the design of the engine in the original Yellow Bird. To that end, it uses a dry-sump lubrication system to provide constant oil
supply and pressure during extreme cornering. Total output is 522 kw (710 PS) at 6,750 RPM and 880 Nm (649 lb-ft) at 2,750 RPM, allowing acceleration from 0-100 km/h (62 mph) under 3.5 seconds and 0-200 km/h (125 mph) under nine seconds. Top speed is 360 km/h (225 mph).
In order to truly pay tribute to the Yellow Bird, the latest CTR will be available exclusively with a newly-developed six-speed manual transmission that sends power to the rear wheels through a limited-slip differential. We began development on the new CTR five years ago with the goal of creating a thrilling, analog driving experience that combines an amazing power-to-weight ratio, manual transmission and modern racing technology,” said Estonia Ruf.
Ensuring excellent handling characteristics, the 2017 CTR uses double-wishbone suspension arms in a pushrod configuration for both the front and rear axles. Internally vented and perforated carbon ceramic brake discs (380 mm front, 250 mm rear) clamped by six-piston fixed calipers (front) and four-piston calipers (rear) offer maximum stopping power and enduring fade resistance.
Minimalist Interior as a Mark of Analog Design
A minimalist two-seat interior designed with lightweight materials is a further acknowledgement of the 2017 CTR’s analog philosophy.
Alcantara is the upholstery of choice both for its aesthetics and weight saving properties that, in combination with leather and carbon fiber, give the cockpit a balance between modern and retro design. The seats are made of carbon fiber, and the pedals from aluminum. A three-spoke steering wheel is a further nod to the car’s racing pedigree, as are the analog dial-type gauges in a green typeface.
Series production is scheduled to begin by 2018 at RUF’s Pfaffenhausen, Germany, facility. The limited run will include 30 units not including the prototype unveiled during the 2017 Geneva Motor Show.
Old 03-07-2017, 01:45 PM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
Very impressive. Would love to own one but its out of my price range.
Old 03-07-2017, 02:15 PM
Ken D
Ken D's Avatar
Incredible.
It speaks to the special nature of the relationship between Porsche and Ruf, that Porsche would allow the 911 silhouette to be used as the basis for another manufacturer's design.
I was wondering if this would be powered by Ruf's bespoke V8, but it appears Ruf have abandoned that product as it no longer appears in any of their model lineups.
Old 03-07-2017, 02:59 PM
Earlydays
Earlydays's Avatar
Interesting dilemma - this or a Singer????
Old 03-07-2017, 04:12 PM
964TT
964TT's Avatar
Zero dilemma, this!
Bit more expensive though, 750K before taxes.
Old 03-07-2017, 04:43 PM
Vandit
Vandit's Avatar
$750k for a completely bespoke 700hp, 223mph car built by RUF seems like a better value proposition than a $500k Singer, but if you're buying either of these cars, you can probably afford both. #poorpeopleproblems
Old 03-07-2017, 04:46 PM
Paul284pt
Paul284pt's Avatar
Ooh! The proportions are beautiful, they have nailed it!
Old 03-07-2017, 05:23 PM
Jjm4life
Jjm4life's Avatar
Not a knock against singer, but this is engineering on another level. Wish it was air cooled though. Amazing car
Old 03-07-2017, 05:28 PM
911Jetta
911Jetta's Avatar
It's got big hips this time!
Old 03-07-2017, 05:29 PM
OMFS
OMFS's Avatar
This is a Singer on steroids.
Old 03-07-2017, 06:09 PM
964TT
964TT's Avatar
Actually they moved the roofline in, instead of the wheel arches out. Its an interesting design.
Old 03-07-2017, 06:13 PM
964TT
964TT's Avatar
Singer is cute. All about show, this is all about go.
The suspension, the engine, the frame, wheelbase, etc.etc...just fantastic.
Old 03-07-2017, 06:15 PM
964TT
964TT's Avatar
Talking with RUF I heard that this car is build with the Nurburgring record in mind. They want to be faster than the 918. (Lambo now?)
Old 03-07-2017, 07:41 PM
s4magman
s4magman's Avatar
Love the car! Wish I could get the LED rear lights and center panel. Like others, wish it had a flat-six aircooled powerplant and doesn't the interior look a little dated with everything wrapped in alcantara?
Old 03-07-2017, 08:23 PM
ctr2
ctr2's Avatar
Absolutely a home run. Congratulations Alois and Estonia !
Quick Reply: 2017 RUF CTR
